What is the procedure to program a remote control ZEN-SPA from Zenith.
Manually turn on the device( TV.,VCR,etc) to be controlled.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the code search button.
Press and quicly release the desired mode button(TV,VCR,etc).The red indicator blinks off once.
Press the CHaNNEL UP button repeteadly(up to 300 times) until the device to be controlled Changes Channel.The red indicator blinks off with each button press.If you overshoot the code required,press Channel Down button to backtrack through the library until the device changes channel.
Press and release MUTE to install the code.
The Zenith universal remote control does not have the CODE SEARCH button. It has only 6 buttons ( ON/OFF; MUTE; V-; V+; P+ and P-). Thank you anyway.
I have the same remote and I can confirm that it does NOT have a Code search button. so I cant press it. because it is not there. The only info I have is a sticker on the inside of the battery compartment that says ZEN-SPA EIA343 SK16-003
