Question about Craftsman 10" Bench Grinder
HOW DO YOU REMOVE NUT TO REPLACE WHEEL?IE STOP SHAFT FROM TURNING,THHAKS
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
There is a left handed thread and a right handed thread on the arbors.
Double nut is the preferred method.
OR
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Posted on Feb 25, 2016
  • 843 Answers
Hi edward, looks like you posted the same question twice. I already answered the other one. good luck.
Posted on Oct 08, 2010
How do I remove the steering wheel in a 2002 Pontiac Sunfire?
Leave key off.Remove the screws behind the airbag and remove (you do not have to disconnect the battery) Now loosen the big nut in the center of the steering wheel.LEAVE NUT ON SHAFT BUT LOOSENED a few turns.Use steering wheel puller OR just grab wheel and pull hard while slightly wiggling the wheel,it should just pop towards you and hit the loose nut on the steering shaft.Remove nut and remove wheel.Always mark wheel location on the steering shaft for easy reinstall alignment of wheel to shaft.
Feb 27, 2018 | Pontiac Cars & Trucks
I have 04 vue. Fwd 3.5. How do i change out right side cv axle? I can't free end that goes into carriage bearing?
remove lower ball joint and remove axle nut in the center of spindle. then move the spindle out of the way separating the axle from the spindle.
Mar 28, 2015 | 2004 Saturn VUE
Removal steering
LOOSEN the the bolts that clamp the fork legs to the tree. Remove the fork legs along with the front wheel by pulling down on them. Be careful that the brake hoses and the speedometer aren't damaged. Remove the center nut. Bend the lock washer tang so that the bearing retainer nut can be removed and remove the nut and washer from the center shaft. the tree should slide out from the bottom. Don't remove the bearings from the center shaft unless you are going to replace them. When re-installing the center shaft, tighten the bearing retainer nut just enough so the shaft doesn't shake but not so tight that there is a bind when turning the tree. this can be re-adjusted after all assembly is complete.
Good Luck
Apr 18, 2014 | 1997 Honda VT 750 C2 Shadow
How do I rgerplabe how do I replace a front wheel bearing?
TO REMOVE FRONT WHEEL BEARING.YOU NEED TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE SITTING ON LEVEL SOLID GROUND.BEFORE RAISING VECHICLE OFF GROUND YOU NEED TO LOOSEN HALF SHAFT AXLE NUT JUST A LITTLE BECAUSE WHEEL IN THE AIR HARD TO LOOSEN AXLE NUT WHEN YOU HAVE HOLD THE WHEEL WHILE LOOSEN THE AXLE NUT WHICH IS TORQUE ON ABOUT 200 FT LBS.USING A SIX POINT AXLE SOCKET SOCKET SIZE COULD BE 34 OR 35 METRIC 1/2 INCH SOCKET.YOU NEED 1/2 INCH BREAKER BAR.ONCE YOU LOOSEN AXLE NUT A LITTLE THEN RAISE VECHICLE THEN REMOVE WHEEL.THEN FINISHING REMOVING AXLE NUT AND WASHER.THEN REMOVE THE CALIPER FROM THE STEERING KNUCKLE AND SUPPORT IT ASIDE USING A PIECE OF WIRE.REMOVE BRAKE ROTOR.THEN REMOVE THE 3 HUB BEARING ASSEMBLY BOLTS. USE A SWIVEL SOCKET GOING TO BE HARD TO REACH SPOT WITH A REGULAR SOCKET. REMOVE THE HALF SHAFT FROM THE HUB BEARING ASSEMBLY.REMOVE HUB AND BEARING ASSEMBLY. PUT EVERY THING BACK VISA VERSA. TORQUE HUB BEARING BOLTS TO 70 FT LBS. TORQUE AXLE NUT 284 FT LBS IF YOUR CAR IS 1998 MODEL AND TORQUE AXLE NUT 100 FT LBS FOR THE 1999 TO 2001 MODELS.THE WHEEL HAS TO BE ON THE GROUND JUST ENOUGH TO KEEP IT FROM TURNING.DONT LET ALL THE CAR WEIGHT DOWN UNTIL YOU HAVE TORQUE WHEEL TO THE RIGHT TORQUE.LET ME KNOW IF YOU HAVE ANY PROBLEMS.
Mar 21, 2011 | 1999 Oldsmobile Alero
How to stop shaft from turning to remove nut and replace wheel
If you put a wrench on the nut on the other end of the shaft, you have a 50/50 chance that the nut you want loose will come loose. If the wrong one comes loose, you can remove that nut completely (and the wheel) then take the nut with you to the store to buy another one. Then put two nuts back on and tighten them together as a jamb nut. Then try again. If the wrong nut still turns, you have to tighten the pair of nuts together tighter. good luck
Oct 08, 2010 | Craftsman 10" Bench Grinder
How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the wheel.
  3. Remove the wheel drive shaft nut.
  4. Remove the brake caliper and wire aside.
  5. Remove the brake rotor.
  6. Disconnect the electrical connector from the wheel speed sensor.
  7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
  8. Remove the 3 hub and bearing assembly bolts.
  9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
  10. Remove the hub and bearing assembly from the steering knuckle.
To install:
  1. Install the hub and bearing assembly to the steering knuckle.
  2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
  3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
  4. Connect the electrical connector to the wheel speed sensor.
  5. Install the axle nut to the wheel drive shaft and hand tighten.
  6. Install the brake rotor.
  7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
  8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
  9. Install the brake caliper.
  10. Install the tire and wheel.
Sep 24, 2010 | Pontiac Montana SV6 Cars & Trucks
Replace velocity axle assembly passanger side
In order for the cv shaft to come out the rotor assembly has to be disconnected from the center shaft ie remove center wheel nut and all other components attached to the rotor assembly except the ball joint and seperate it from the shaft.
shaft might be held in place with circlip[s or will just slide out with a hard pull.
Sep 21, 2010 | 2000 Toyota Camry
How do you get the pulley and nut off on the cutting pulley to change it?
The easiest way is with an impact tool. It will spin the nut faster than the shaft can spin and will remove it very quickly. If you do not have an impact tool, then you will need to stop the shaft from turning. Put a large clamp onto the under side of the deck and then rotate the blade around against it. This will stop the shaft from turning while you remove the nut. If you have already removed the spindle assembly from the deck, you will have to clamp the lower end of the shaft in a vise to be able to remove the nut. It should be a standard threaded nut, which will remove when turned counter-clockwise.
Sep 11, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Stiff mixer tap
You need to remove the top from the tap that is stiff, this is normally done by removing a cap or plug from the top of the tap using a small screwdriver or some other form of lever, underneath you should find a screw, removing this screw should allow you to remove the tap handle/knob.
You should now be able to see the main shaft of the tap, where you have just removed the screw from. work down this shaft and you come to a nut, this is known as the packing nut, it places pressure on a seal to stop water coming back up the side of the shaft. It may be that this nut is a little too tight and is acting like a brake, you need to loosen this nut (anticlockwise) but not too much that water is allowed to seep out from the shaft, try a little at a time, (you also need to hold the bigger, lower nut to stop this turning) It could also be that lime-scale has formed on the bottom of this shaft, if this is the case you may need to replace this part of the tap, the bigger nut further down the shaft allows you to unscrew (anticlockwise) the tap from the main body and replace this part.Remember to turn off the water at the mains shut-off before removing the tap body. If replacing the tap body it needs to be tightened down to prevent it turning when turning the tap on and off.
Apr 10, 2010 | Home
Craftsman 10" Bench Grinder Logo
641 people viewed this question
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
