Question about Audio Technica ATH-CK7 Headphones
I can't hear anything - Audio Technica ATH-CK7 Headphones
My phone model is SGH-B520. I am not able to hear anything while making calls or attending incoming?
Hi, what makes you not to hear anything when making calls is because the earpiece is faulty.
The earpiece is a small speaker at the top of the phone where you put on the ear in other for you to hear anything when calling. You need to replaced it with another.
When you replaced the speaker, you will now be able to hear when people call you.
Take care.
Jun 08, 2010 | Cell Phones
Cannot hear anything.
The problem with your phone is that the earpiece of your phone is bad that is why you cannot hear anything while calling.
All you need to do is to replace the earpiece of your phone so as hear people while you call or when they call you.
Change the earpiece of your phone as advice and you will see that you will hear clearly when calling people.
Take care.
May 04, 2010 | Pantech Matrix Cell Phone
Can not hear sounds or calls. when someone calls the phone i can not hear the but they can hear me. when i try to play music i can't hear anything.
Since you cannot hear your caller or even when you call, you hear anything but they can hear you.
The problem with your phone is that the earpiece of your phone is bad and will need to be replaced in other for you to hear when you call or when they call you.
Replace the earpiece as i said and you will see that your problem is solved.
Take care.
Apr 25, 2010 | LG Vu CU920 Cellular Phone
I cannot hear anything. When I get a phone call I cannot hear the person and I cannot hear anything when I call out. It is as if it is mute but there is no mute on.
Hello!
Y ou cant hear anything if the ear piece is bad get a technician to check it with a multimeter if faulty replace it .
The ear piece could be damaged by liquids ,dirt, or its coil shorted
and sound won't come out of it .
good luck
Oct 06, 2009 | Motorola Mobility RAZR V3
Cannot see anything, can;t hear anything
check that your yellow cord is plugged into the right hold and the red and white are plugged into the right hole. this should work, if problem consists i suggest getting a new video cord.
Sep 25, 2009 | Microsoft Xbox 360 Console
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Cant hear anything
ya im having the same problem with mine, and im trying to play cod6. but i think its supposed to do that. but then again, why would they give u a earpeice if u cant hear anything. well, u can try pressing the volume up on the head set, and also go to accessory settings on your ps3 and turn it up. but im not sure if thats your problem, i havent tryed that yet. but hope it helps.
May 26, 2009 | Mad Catz Radio Communications
Can't hear anything when I used my bluetooth ear piece
When connecting, you must be sure the phone is set to connect to the model of bluetooth earphone you are using, and the connection goes through, Once it makes the connection, it will stal connected until you disconnect it, again using the phone's disconnect key.
May 26, 2009 | Google Android
Audio Technica ATH-CK7 Headphones Logo
44 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
