Question about Sub-Zero 650/SRH Stainless Steel
I HAVE A MODEL 650 AND I CANNOT GET THE FRONT GRATE OFF TO CLEAN THE CONDENSOR. I HAVE TAKEN THE SPRINGS OFF BUT SOMETHING ELSE IS HOLDING THE BOTTOM OF THE GRATE.
    Sergeant:
    Champion:
  • 351 Answers
There are three screw on the bottom side that hold it down take them out it will come off
Posted on Oct 08, 2010
How to open sub-zero 650 condensor cover ?
The cover has 3 bolts, open refer unit door, in the ledge of the box just above the door, you will/should fined 3 screws. Remove them and tip the panel toward you slowly, release the two springs and remove panel. Good Luck
Aug 01, 2014 | Sub-Zero 650 / O Bottom Freezer...
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Refridgerator is not gettting cold
    there might be a leak in your condensor did you try cleaning your coils pull the grate off the bottom and clean coils ie vacuume or air compressors work the best blows everything off if that dont work try the reset button its in one of th corners on bottom turn with a screwdriver that might work
    Dec 02, 2009 | Refrigerators
    Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
    The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
    Nov 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
    Sub zero 650-display
    If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
    Oct 03, 2008 | Sub-Zero 650 / O Bottom Freezer...
    Sub zero vacuum condenser
    Top of grill is held by a spring. Pull out the top and lift the grill to remove. It can then be dropped down out of your way.
    Jun 01, 2008 | Sub-Zero 650 / O Bottom Freezer...
    Subzero model 650 needs the condensor cleaned
    The best way to clean the condensor coils on this model is to blow it out with an air tank.
    Jan 07, 2008 | Refrigerators
    Sub-zero 650 / bottom freezer
    Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
    Aug 09, 2007 | Sub-Zero 650 / O Bottom Freezer...
    Sub-Zero 650/SRH Stainless Steel Logo
    104 people viewed this question
    Top Sub-Zero Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    ACME Sub Zero...
    ACME Sub Zero...
    Sal DeAngelo
    Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
