Question about Sony STR-GX700ES
My sony gx700es receiver will not turn on. no sound no lights but when you punch the on button it makes a normal sound as if it is turning on. The receiver is about 20 years old. Is this a terminal problem or are there some issues that might be fixed?
SOURCE: no sound coming from subwoofer
Your receiver does not have a power amp to drive the speaker in the subwoofer while your other amp did. With this receiver you need to use a powered (active) subwoofer which has it's own power amp in it. You can either change out your subwoofer to a powered (active) subwoofer, or keep using your passive (unpowered) one and add a power amp between it and the receiver. The easiest way to tell a powered subwoofer is to see if has a place to plug it into the wall. If it does, it will most likely work in this situation.
Posted on Feb 19, 2008
gman63b
  • 9 Answers
SOURCE: Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
aborcass
  • 2651 Answers
sorry my expertise is in appliances, youl need to repost you question to another tech
Posted on Mar 22, 2008
futurework
  • 70 Answers
SOURCE: flashing word "Protector"
Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
Posted on May 05, 2010
freetek
  • 5568 Answers
SOURCE: My Sony STR-DE685 Receiver out of the blue now has
In receivers, there are different power supplies or power supply outputs for the receiver and amplifier sections so you can have separate failures with one area not affecting the other. From your description, I think the (probably lower voltage) section for the receiver has either lost a cheap filter capacitor or a regulator IC. Neither of these are expensive parts but I can't know what labor costs in your area might be. An honest tech shouldn't ask more than ~$100 US for that kind of repair.
Posted on Apr 16, 2011
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
When I turn off my truck and the blue lights on, it turns off but when the radios on and I turn the truck off the radio does turn off unless I hit the off button! Help sony xplod cdx-gt640
do you mean the blue light on the power button? it sounds like your radio's switched power input (usually red) is hooked up to a 12 volt constant source.
Feb 22, 2010 | Sony XPlod CD Player w/MP3 Playback...
My kenwood receiver is on but no sound
Check that the tape monitor (or tape 2) is not on. To turn it off press the tape 2/tape monitor button. Turn the volume down first!
Feb 01, 2010 | Sony STR-DE325 Receiver
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
No picture, no sound, standby button doesn't work normally
Make sure all your connections are tight and if you're using hdmi try using component cables.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Volume turned way up just to get enough sound
On 5.1sound set up, its normal as sound varies in Dolby Pro Logic or DTS.
Jan 22, 2009 | Sony STR-DE697 Receiver
The protector light starts flashing every time I try to use my sony tuner.
My protector light flashes on and off, whats up with the reciever ?
Jun 22, 2008 | Sony STR-GX700ES
Mar 20, 2008 | Sony STR-DE635 Receiver
124 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
