For stuck CD do this: Windows should now be configured to use these devices for both playback and recording. This should fix your problem, if not use link to go to Sony support. Use the E-Mail option for a faster solution.
Hit Ctrl,Alt and Delete all at the same time> Windows Task Manager should open> Click on the "Applications Tab"> Click End Task to close all Apps.> Now go to your Cd/Dvd player hit the eject button on the front.> Remove CD.
Now for your device problem try this:
To specify your preferred audio devices for playback or recording in Windows, do the following:
Windows 98, 98se, ME:
1. In Control Panel, double-click Multimedia or Sounds and Multimedia.
2. On the Audio tab, select the devices you want in the Preferred Device boxes.
3. Click the Use Preferred Devices Only check box to select it.
4. Click OK.
Windows 2000 and XP:
1. In Control Panel, double-click Sounds and Audio Devices.
2. On the Audio tab, select the devices you want in the Default Device boxes.
3. Click the Use only default devices check box to select it.
4. Click OK.
Windows Vista:
1. Go to Start > Control Panel
2. In Control Panel, select the option that says Hardware and Sound
3. Under the listing for Sound, select Manage Audio Devices
4. Under Recording and Sounds tabs, you will find all available devices. To set a default device, right click on one of them and select Set as Default Device.
http://www.sonycreativesoftware.com/support/
