Televison & Video Logo
Posted on Oct 08, 2010
Have amber light on but will not turn on - Westinghouse TX-42F430S Television
Blinking amber light
power board problem
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dellâ„¢.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dellâ„¢.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dellâ„¢.
On a 2004 Hyundai Accent 4 door, are both bulbs in the amber light supposed to be turn signals? I have no "parking" lights, and both bulbs in the amber section blink only as turn signals. The manual is...
okay,the bulbs are amber for the turn signals.
the parking lights actuate by turning off the ignition and moving the indicator arm left.right.(not all markets)
4helpful
2answers
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Stuck on amber light will not turn on
An amber light normally means that there is no signal getting to the screen, if it was stuck in standby then the LED would be red.
Please check your connections to cure the fault
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
1helpful
2answers
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
2answers
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
