Question about HP LaserJet 1200 Printer
Power conversion i want to convert my hp laserjet 1200 series from 110v to 220v so i can use it in NIgeria. plz help me for some one asked me to help him do it. i know some components need be removed and replaced but i dont know which one.need help plz
  • 10,594 Answers
Dont do any thing with your printer power supply and just purchase Step-Down AC Transformer. Its input will be 220Volts AC and will out 110Volts AC. One thing important, read the printer power consumption watts and get proper one. Got the point buddy?
Posted on May 29, 2008
I have m1217nfw is there convertor to power from 110v to 220v
I have worked on laserjets for years now and have never heard of a power convertor. The power supply will be a 110v device and if you want to use it in the uk you will need to replace it with a 220v one. I am unable to find a parts list for a laserjet M1217. However you must look for the C number which will be on a label. Note this and go to HP.com site and click on the parts link. Enter the c number and it should find what parts are available. If it does not find anything then HP will not supply parts but as its a laserjet there should be some available.
Mar 14, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Want to convert hp laserjet 3055 from 110v into 220v
You maybe able to get a new 220v power supply board and swap it out in the printer.
The other way is to get a 110v to 220v step up transformer, make sure the current rating matches or greater than the printer's requirements.
Aug 23, 2012 | HP LaserJet 3055 Flatbed All-in-One...
Can i use philips hair straightner hp 46666 from canada in india
yes definitely u can use...
Please refer to user manual for power rating...
In India the voltage used is 220v whereas in Canada its 110v
some machines can work in both the voltages...certain do not...
In this case you can use a voltage converter to convert 220v to 110v...
Feb 10, 2011 | Philips Computers & Internet
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Hp laserjet 1320 has no power at all.
Try connecting the printer to a circuit board (one with a circuit breaker) to ensure overvoltage is minimised. Next check that the printer has the appropriate power setting (220v/110v Depending on your area.) Ps- not all fuses are the same , if you have the original 1 look on the adaptor and it will say 220/110V at ?A thats the proper fuse to get ,if you replaced a different fuse (lower rating) it will go out instantly.if the fuse still goes out you will need to ask Hp for a replacement adaptor for your printer.(if none is available you need to either take it to hp (costly) or buy another printer .
Hope it helps
Oct 08, 2008 | HP LaserJet 1320 Printer
Hp1200
Converting a power supply from 110 volts to 220 volts input isnt't easy task buddy. it needs alot hardware changes in it and there is not gaurantee of compatible electronics parts. I gave you a simple and economical solution/ suggestion. final decision will be yours.
May 30, 2008 | HP LaserJet 1200 Printer
Power
The easiest and safest way would be to simply buy a step up transformer, available from any electrical store..
May 28, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1200 Printer Logo
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
