My computer fan is making noises..needs to be fixed..is it better to have a place do this or can I do it myself?
    Problem Solver:
VERY SIMPLE U CAN DO IT. MOST LIKELY THEIR SAT APART FROM ANYTHING U CAN DAMAGE MAYBE DIRTY IF NOT IT NEEDS TO BE REPLACED
Posted on Oct 08, 2010
Laptop making noise
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Aug 06, 2013 | Toshiba Computers & Internet
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
My kirby is making a very loud noise and somehow the white fan inside has broken. I have the pieces. What do I need to do? I can't find a vacuum repair place near my location. Can I fix this myself?
What you need to do is a long process of taking apart the vacuum apart. Your fan broke so you are going to need a new one. So go to Kirbys website and look up a nearby vacuum store. Or More recommended a Kirby. It is a long process of taking the vacuum apart,
Mar 26, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Equium P200-1ED.
yes the fan can be changed before that your noise making fan can be fixed only you have to do is that unscrew the fan first take small brush clean the fan leafs and blow some air from your mouth to the bearings and motor part put a few drops of oil or 2-3 drops of oil in side bearings and slowly rotate your fan with your fingre to and fro so the oil can reached to the bearings and it will get lubricated wait for five mintues and fix the fan back in position and you can use it ot need to add more oil to it again add 2-3 drops thats all once the fan is lubricated it will not make any sound in the future this is applicable to all cooling fan it is must that once in a year you should lubriacte the fans for better perfomance and it will get more life too.....
Oct 12, 2009 | Computers & Internet
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Lap top fan making a lot of noise
Check places like TigerDirect.com or Newegg.com. They have high quality laptop cooling fans & should be able to help you find one that is better than the stock fan at a better price. Hope this helps & please remember to rate my answer. Thanks.
Jan 08, 2009 | Gateway M675 Laptop
Card Fan
Without the fan your card may burn. Go to your nearby Pc junk store and get a graphic card fan of same size and voltage. To remove your fan from the card try to push the plastic pins located on the corners of the fan's body. Hope it works .Don't forget to vote me. Tell me again so i may fix your problem. Thanks
Mar 28, 2008 | ASUS EN7800GTX GeForce 7800 GTX, (256 MB)...
Help with motherboard fan making noise
the cpu fans are available in market for pretty cheap rates...
better you can replace it....
thankyou...
Mar 13, 2008 | ASUS A8N-SLI Motherboard
Laser 72 exhaust blower noise
the combustion blower sucks in clean air so it has no place in the exhaust stream. hence no carbon build up. the blades of it look like a vacuum disk on a vacuum cleaner. if the fan was recently rebuilt, make sure of the placement of the bushings. if one is misplaced the fan will rub on its housing and make all kinds of racket.
Dec 16, 2007 | Rinnai Toyostove Direct Vent Heater:...
Computers & Internet Logo
David Payne
David Payne
