Question about Frigidaire FAD704TDD Dehumidifier
We have the hose attached to drain it but the bucket gets full instead and when the bucket is full it turns off. We have had several people look at it but it still does not drain through the hose.
    Problem Solver:
  • 8 Answers
The hose mignt be cloged or obstructed in some way.take it off completely and try to blow through it.
Posted on Oct 08, 2010
Dehumidifier manual
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Aug 17, 2014 | Dehumidifiers
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Aug 15, 2017 | DeLonghi 50-Pint Electronic Control...
The dehumidifier will not run. It has power to the control panel but the "bucket full" light is flashing RED. We have a hose hooked up to the unit to drain the water and we have check the bucket...
Generally, the buckets on these units can be a little finicky. Especially, if the bucket is not installed properly. In other words, if the bucket doesn't trip the safety switch, when it's out in place and the "bucket full" indicator will remain on and the unit will not run. I suspect the hose attached to the bucket may have gotten the bucket slightly out of place and it's not triggering the safety switch. Turn the unit off, and reinstall the bucket,. Then turn the unit back ON. Make sure there is a little slack in the hose from the unit to the where ever you're draining the water to. In other words, the hose should not be pulling on the bucket.
As I said, they can be a little finicky, so be patient reinstalling the bucket. As it may take several tries, before you get it right.
Hope this helps solve the problem.
Mar 10, 2011 | LG Dehumidifiers
We had a hose attached to empty into a drain, but the hose came loose. Now it won't run because it shows the bucket is full.
Was the hose attached to the bucket or directly attached to the inside of the humidifier?
If it was to the bucket, the hose may have slightly pulled the bucket out of place, disengaging the safety switch. Unplug the unit and wait 5 minutes. Then plug the unit back in. Turn it to ON and remove the bucket and carefully reinstall it. You should hear a "click" sound when it's properly in place and the unit should start back up,
Hope this helps to solve your problem.
Mar 10, 2011 | Maytag M7DH45B2A Dehumidifier
Hi, I have an LG dehumidifier, model number LHD650EBL. I have a hose attached and inserted directly into a drain in my basement, bypassing the water tray. Problem is, my dehumidifier is saying...
Try to see if operating the float lever by hand can make it turn off the 'bucket full' message. Maybe use a rubber band or tape to keep it in the on position vs. the 'bucket full' off position.
Check to see if the bucket has to be inserted for the unit to operate, and if the bucket has a nozzle to hook a hose up to at the bottom. I have a dehumidifier of a different brand that has this feature that works with the bucket in, but with the drain nozzle on the bucket connected to a plastic tube that leads to a drain for continuous operation without having to empty the bucket.
How is your hose attached to the unit if it isn't attached to the bucket?
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
May 04, 2010 | Whirlpool AD50USS Dehumidifier
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Frigidaire FAD704TDD Dehumidifier Logo
295 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
john h
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
