Question about Samsung Televison & Video
When i turn on the tv, it takes maybe a minute or two to turn it on.. red light flashes as it try to turn on what is wrong with the TV
  • 597 Answers
The reason your television takes a while to come on and have a red light flashing before it comes on is because it is about to develop a problem and it is most likely a power problem.
If your television does not get properly shut down and power goes off on it without the proper procedures, it would start to flash the red light which is to sound a warning that your television would become faulty within a short period of time.
So ensure you go through the normal procedure in turning off your television.
Take care
Posted on Oct 08, 2010
I have a sony wega kdf-e50a10 I replaced the lamp and the tv still does not come on. when plugged in the green light starts to flash this happens for about a minute before it goes to flashing red...
Without having a technician there to diagnose this problem is going to take some troubleshooting. First, I would take the lamp back out of the TV and then reinstall it and try turning the TV on again. If that does not work there could be numerous things wrong with the TV. The heat sensor in the TV could be bad or the actual light engine, which is essentially the heart of the TV, could be bad. If it is the light engine then it is cheaper to buy a new TV.
Feb 26, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Red and green lights flashing intermittently when we turn it on.
take it back to place purchased /with receipt demand new one
Dec 24, 2017 | Sharp Aquos LC-19D45U 19 in. LCD TV
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
