Question about Epson Stylus Photo R260 InkJet Printer
I just replaced all the inks in my printer. When I try and print only every couple of lines print. what should I do
  • 386 Answers
Hi Good day!! Maybe you need to clean the head. to do that you need to do the head cleaning.
here are the step:
1. Click "Start
2. Choose "Setting" and then "Printer and Faxes" you should see your printer installed.
3. right click your printer and then properties you should be on the printer properties box
4. Click "Printing Preferences" now you should be on the Printing preferences box. there are 5 tabs go to the "Maintenance tab"
5. Select "Head Cleaning. and then you can start the cleaning of your printer head..
after you clean it try to print again and see if your printing was fine if not you should clean it again back to start.. .
Hope my solution helps you..
Regards
JR
Posted on Oct 08, 2010
    Scholar:
  • 59 Answers
Click the start button, go to control panel. Open up printers. Right click on your Epson printer and click on printer properties if it's there or just properties if it's not. Look through the tools provided by your printer such as clean and align print head. Use the tools as directed. Try to print at least a test page regularly to keep any ink left in the print nozzles from becoming overly dried and tough. You may need to run a cleaning or deep cleaning several times and align the head. If these steps do not solve the issue, it may be time for a new printer.
3 Suggested Answers
Inky
  • 691 Answers
SOURCE: Prints only slight blue
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
Posted on Jun 29, 2008
cns assoc
  • 677 Answers
SOURCE: my printer was printing fine, iloaded new ink
Epson does not like Generic/Compatible Cartridges
MUST BE GENUINE
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
Put back in Genuine Cartridges, and see if it works. This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Just replaced all of the print cartridges. Now print is blurry looks like double print
First perform ink head cleaning a couple of times as follows. 1)Press Ink, 2)Press arrows to choose cleaning and press OK, 3)Press arrows to choose all and press OK. Do this a couple of times. Then you can perform check print quality as follows. 1)Press ink, 2)Press arrows to choose Test print and press OK, 3)Press arrows and choose print quality and press OK, 4)Press color start. the machine will print a chart. Inspect the short lines on the four color blocks If any are missing follow on screen instructions.
Feb 19, 2014 | Brother MFC 6490CW InkJet Printer
Hi, I have a Canon PIXMA MP210. Today it started to behave strangely. I am trying to print a page of pdf document. Pixma only prints a couple of lines on one page and goes onto the next page to print a...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 02, 2011 | Office Equipment & Supplies
Our Brother MFC-490CW printer prints yellow, blue and red but won't print black even though we just replaced the black cartridge. We've checked everything about the new cartridge -- we took off the...
you have air in the air line tubes. you can try doing a couple cleaning, wait 24 hrs, and try a couple more cleanings and then do a test print.
you can try doing a ink purge, but it will **** up a lot of ink, but it might be your last resort.
press menu, and then *2864 quickly, then type 76, use the arrows to select black and then press 0.
when all done press 99 to exit.
It may work it may not, its possible you may even need to do it again, however, your inks will be depleted.
Aug 12, 2010 | Office Equipment & Supplies
Printer will not print clearly
im sure you have heard this put are you sure you have the right driver, Or your printer cartridge could be dispersing too much ink at one time try replacing them.....
Driver Download
Apr 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson 440 won't print
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
Jan 06, 2009 | Epson Stylus Color 440 InkJet Printer
Black lines running through certain lines of printed documents
Hi, ok your ink well is clogged (the stuff the ink cartridges fit in) remove all the ink tanks, then remove the inkwell by pulling the lever to the right. In a dish pour some rubbing alcohol and tel the ink jets soak a bit. pour some alcohol over the nossles(where the ink sits to send the ink through) and let it soak a bit more. Use a straw and cover the jets then blow, this will force the bad ink out clear the jets. Blot it dry then replace. blot each inktank before replacing them to insure the ink is running out. A couple of deep ink cleanings and you will be set.
If this fails you may have to replace the ink well and the cartridges (order new ones from canon) But cleaning it should work, try at least 3 times before deciding to buy a new one.
Dec 16, 2008 | Canon iP4500 Photo Printer
4580 all in one less than 6 mos old started printing half lines
try to clean the print heads of the ink cartridges. you can do it in the HP solution center. you can run it through all 3 tests so you make sure its clean. if it doesnt work after that, your ink cartidge level might be off, because i hear they never work half the time anyways. i would buy new ink if the cleaning the heads does not work. good luck!
Nov 12, 2008 | Office Equipment & Supplies
COLOR NOT VIVID
The DeskJet 940c is not really the highest quality printer out there on the market. However, having said that, the printer is still capable of producing decent quality printouts. You might play with your printer settings for print intensity, lightness, ink volume.
May 10, 2008 | HP DeskJet 940c InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
477 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
