Maytag washing machine only fills with water
My washing machine blew a fuse inside the back cover, so I replaced it and now it only will fill with water, nothing else
  • 525 Answers
You will also need to replace the check switch to get it operational again.
The white microswitch is usually the switch that fails,(Check switch).
You can look for parts yourself by going to www.repairclinic.com
or any of our sponsors on this website.
Posted on May 29, 2008
  • David Emmel
    David Emmel May 29, 2008
    Hope you can view this picture.
Cold water will not fill
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 27, 2011 | Maytag Washing Machines
My maytag lat8214aae will not fill up with water
heatman101
Feb 09, 2011 | Maytag Washing Machines
Will not fill with water
heatman101
Jan 29, 2011 | Maytag Washing Machines
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
heatman101
Sep 06, 2010 | Maytag Washing Machines
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Light turns on but no water fills up.
heatman101
Aug 31, 2010 | Maytag Washing Machines
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
My Maytag Model# LSG7806AAE Seriel# 15951872UW washer won't fill with water. I advanced the switch and it goes on when you get to the rinse and spin, but still no water.
After having a repair guy quote me $450 to fix this problem, I took it on myself. I first changed the lid switch as the repair suggested. No luck. Next, I changed the washer timer. Still no luck. Next, I disconnected the water tube and filled the washer with water ( a step I wish I had done first) and turned on the machine. The machine spins, drains, etc but still didn't fill. I changed the water valve. Still no luck. Finally, I changed the 50 cent fuse in the front left corner of the washer unit. Success! The fuse was the problem. The washer now fills correctly.
Jul 24, 2008 | Maytag Washing Machines
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
