Question about Refrigerators
Please can u help me? i got a question, i got a conservator by crosley (regrigerator) model cth-143-ww-01 the problem is i need the magnetic inside the frame of the door, can u please tell me where can i buy it? do u sell it? how much is it? thank you!
4 Suggested Answers
SOURCE: BROKEN DOOR BRACKET
Reliable Parts http://www.reliableparts.com/ has them in stock. The parts are made by Serviplus. According to Eric at their main number, there are several in stock in the San Francisco store. I called 877-733-9241.
One word of warning: when I went to pick up the part (I needed only the 221C6568), the first one they brought out was a 221C6578 that was mislabeled. You might want to ask them to verify before they ship them.
Posted on May 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: crosley conservator is freezing, fridge not cooling
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: my crosley conservator frig is producing a fowl
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 10, 2011
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
I taped magnets on my regrigerator according to the suggestion from Samsung. It worked for a couple of months but now it went haywire.
Please help me understand the connection between magnets and the like flickering? Does the light act the same way when you open the right door? have you played around with the switch?
Dec 08, 2014 | Samsung Refrigerators
Hi Team. I too need a diagram to install the belt on my 2007 Husqvarna CTH2036 cutting tray. Can you help please. serial. 082207C001009. product. 960610217 01
The CTH machinesw have counter rotating blades, there should be a scimatic of the belt routing on the underside of one of the foot wells
Dec 03, 2012 | Husqvarna Garden
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
Ice is forming on the coils of my Crosley Conservator. I used compressed air to blow out the grill and coils but it did not help.
most dehumidifiers will freeze up when it gets below 70 degrees. if where you are running it is below 70 degrees, then you need a different style. whirlpool makes a model specifically designed to run in colder climates. best buy or other that has whirlpool stuff.
Oct 27, 2009 | Frigidaire FDL25P1 Dehumidifier
Manual trouble
Sorry can't help...
Feb 09, 2009 | Lakewood CTH-2 Heater
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
Need replacement freezer door for model Crosley WCK05W
are u sure thats the right model # ..can't bring nothing up on that model # Did u get it off a tag that said model#?
Sep 27, 2007 | Crosley WCK05W Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
