Question about Thermador SC302T Electric Double Oven
I have a thermador oven m#SCD302TP reading -F7 // HELP
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
Macmarkus
  • 2605 Answers
SOURCE: The control panel on my Thermador scd302tp will
Hello, welcome to Fixya. To answer your question "Is there a cheaper fix?" In a word...maybe. **Turn off the breaker before attempting any service suggested here please** The first thing to look into is to check the harness which comes from the main relay board to the display head, they can become unsecured from the display or the main relay board/control and that will affect the display in a negative way, i.e. faded or no display illuminated. You may or may not be surprised how much those things vibrate under normal use with the cooling/convection fan running etc. and over time the harness becomes unsecured. Check "J1" on display head as well as "J1" on relay board of the display power harness and insure they are secure in place, wiggle them a bit to see if the display illuminates when turning the power back on. If that doesn`t yield any positive result`s you`ll need a new display head kit part # 492067, it comes w/harness and main relay board ( see image below ) and it is typically about $250 or so, but I haven`t had to purchase one in 4-5 yrs. I`ve checked repairclinic.com and their site says it is discontinued, but if it turns out you need one I may have one in my garage. ( I used to have my own appliance business, hence I still have some "new old stock". we can communicate via email if need be ) Let me know what you find and how it goes with the harness check, I`ll watch for your reply on your post here. I`ll cross my fingers for you it`s just a loose harness. Hopefully this was helpful to move you forward and shed some insight on what to look for at least. Good luck macmarkus :)
Posted on Jun 18, 2010
Macmarkus
  • 2605 Answers
SOURCE: After I cleaned my ovens
Welcome to FixYa.
To address your post, looking for an over-temp cut-out tripped. Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door ( just below upper door) next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Hope that answers your question and gets you back up and operating. Good luck.
Regards,
Macmarkus :)
Posted on May 29, 2011
Macmarkus
  • 2605 Answers
SOURCE: I'M LOOKING PART OF THIS
Hello, welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Posted on Sep 19, 2011
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Where can i find a relay board #492069 for thermador model SCD302TP?
try having it rebuilt at core centric solutions dot com. they bring new life to most old electronics.
Feb 09, 2013 | Thermador SC302T Electric Double Oven
F7 code
You'll have to provide a little bit more information......Sorry, but all Thermador ovens are NOT the same
Apr 15, 2012 | Thermador Ovens
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
After I cleaned my ovens the top one doesn't heat anymore. I was told that the circuit fuse button has to be reset. We can't locate it. Can you please help? The model umber is: Thermador SCD302TP
Welcome to FixYa.
Regards,
Macmarkus :)
May 29, 2011 | Thermador SC302T Electric Double Oven
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
I have a thermador oven m#SCD302TP reading F2 F5 // HELP
F2 -Oven temperature too hot
Replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).
Thank You
Sep 03, 2010 | Ovens
F7 error
Jan 11, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
64 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
