Hello I have a Kelvinator washing machine model #KWS839AS1 the problem I'm getting is that when I turn on the machine to the required cycle it isn't coming on but when I put it on the spin cycle it works. Can you tell me if the timer is the problem I was told that sometimes the contacts in the timer burn out from time to time. I would really appreciated it thank you in advance.
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
SOURCE: WASHING MACHINE
washing machine goes through whole washing cyle without draining.
Posted on Mar 27, 2008
  • 3230 Answers
SOURCE: Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Posted on May 17, 2009
heatman101
  • 43501 Answers
SOURCE: machine is not agitating and spinning regularly, Timer?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 18, 2010
I have Kelvinator AQUA EXTREME KL600FL lost manual and now dont know how to do the various settings for washing programmes
I am including a link to the kelvinator support center. It seems that KL600FL may not be the complete model number because the site does not answer anything for that number. . Open the lid or door and look around the frame for a model number label.
Support centre
Oct 03, 2014 | Washing Machines
Hi my washes agitators is working but it won't do anything else. It's not spinning or rinsing the clothes. the knob isn't moving from cycle to cycle. Even if I manually put it on spin cycle it...
Hello, Thank You for using FixYa. I will be helping you today.Check the lid switch. Since you didnt give a model number it makes it hard to figure out but sounds like the lid switch
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Roper Washing Machines
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
I would like to know how many belts a kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136. the end cycle buzzer will not shut off once the cycle comes to an...
Hello dmjohn39,
Welcome,
I am Huuum at your service!
You said,
You would like to know how many belts a Kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136.
The end cycle buzzer will not shut off once the cycle comes to an end
It appears to take only this one belt according to the book!
You can find the belt at one of our many our Sponsors, site below!
I have typed the belt # and cost for it at the site.
I am sure they will have the buzzer too!
Item # Price
3372 $14.10 + 4.00 shipping I believe
Dryer belt length 87 3/4”, width 1/2”, characteristics, flat
Recommended related item(s):
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Thank You for using fixya.
I was happy to solve your questions!
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire CWS3600AS Top Load Washer
User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Dec 06, 2007 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
