Question about Relic 0504648FA
Where can I purchase a crystal for a Relic Wet watch. Could you tell me the price.
  • 831 Answers
Thank you for contacting FixYa.
You can try contacting Relic at this link to see where to send for a replacement:
http://www.relicbrand.com/contact.htm
You can also try a local watchmaker. Depending on the crystal, most can be cut to fit and the price varies depending on the type of crystal, difficulty, etc. Take to a local shop for estimate.
Hope this helps!
Jewel
Posted on Oct 08, 2010
Where to find batteries for relic watches?
Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
May 26, 2014 | Relic Wet ZR11672 Wrist Watch for Women
Relic Wet ring around the crystal
this may be silly but, in some watches you can actually rotate the outside ring. try rotateing it does it move at all? a local watch service should be able to adjust it if its locked in somehow, if you pull the plug out would it move then?
Aug 16, 2008 | Relic Wet Multifunction ZR15385 Watch
I have a Relic watch with crystals around it, Two of the crystals have fallen out. How might I get these replaced?
If those are rhinestones it will lose it's color if you were to replace them. If it's Austrian Crystals or better you can buy them single on ebay and have a jewelry repair person re-attach them for you.
Feb 10, 2013 | Relic Watches
BATTERY REPLACEMENT FOR RELIC WET WATCH ZR11657????
If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example 375R, 325LRW, etc. the 3 digit number is the type of battery you need. If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
i hope i helped!
Jul 17, 2011 | Relic Wet ZR11657 Watch for Men
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
The crystal is cracked in my Relic mens wristwatch. Can I order a crystal on-line and replace it myself?
Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
Oct 02, 2009 | Relic Multifunction Watch
Relic doesn't run. TheFossil is missing the bezel.
There is a little tab next to the battery that should have an arrow pointing to it. You will have to depress the tab with a pin to get either the watch to start, or the eight ball and flames to start flashing, after replacing the battery. If this doesn't work, the watch is probably junk, as the movement has been damaged from the impact that broke the crystal. I have done this exact thing on this type of watch two years ago, which is how I know, except that the flashing image in the background was the chinese characters for love, peace, and happiness. It was also a Fossil Relic. Hope this helps. Bilal Hassan Clarksville, MD
Jun 03, 2009 | Watches
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
Relic 0504648FA Logo
261 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
