Cars & Trucks Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oil indicator light is on and i dont know what the probelm is?
Drew Z
Level 3:
  • Dodge Master 681 Answers
  • Posted on Oct 08, 2010
Drew Z
Dodge Master
Level 3:
Answers
681
Questions
5
Helped
217779
Points
2096
It's usually an indication of low oil pressure. You can try changing the oil and adding a stability agent. The main bearings create and maintain the oil pressure so it's a good indication that they are getting worn.
I dont know what the warning lights on the dash indicate
A Chilton manual will tell you that, and other things to keep this fine car going.
My 04 pontiac grand am gt wont start check engine light ,battry light, oil light comes on wheh the igniyion switch is off
Check the code what is wrong.Try to reset the light first see what happen.Need OBDII scanner.
1helpful
My oil indicator light goes on and off
DONT overfill with oil,,thats just as bad as not having enough..Theres two things probably going on..Either you have a bad oil pressure switch,,or you are having a low oil pressure problem..Sometimes i heard that a cheap oil filter can cause that too..Is there any other symtoms,,like excessive ticking when the light comes on,,or does the vehicle act different..If no other symtoms its probably the oil pressure switch,,If you know how to work on cars or know a good mechanic,,you can put a pressure gauge and that will tell ya for sure
2003 Toyota Avalon -- 124K miles -- Oil light and check engine light came on -- code indicates crankshaft and camshaft out of sync -- what do you think this means???
there may be a timing belt problem. I dont know about the oil light,Check the oil level, but it needs attention ASAP
Change engine oil light is on. Occassional goes out while driving. Start up and at idle the light stay's on? I'm thinking it may be the oil sending unit? Don't really know? Your suggestions? And the...
If it says "change engine oil" then its just a service light.Check your oil level and oil pressure and reset the service indicator[No Buicks in Ireland so i dont know how to reset it Sorry]
1helpful
2answers
I have a 1998 ford explorer xlt awd,4.0 (x model) My probelm is I'm hearing a rattling noise in the motor. I dont hear it at a idle only when its about to shift in the next gear. Or when I'm half way up a...
oil pump maybe tired or bearings worn out, try more heavy grade oil, if that helps sounds like bearings, and maybe an overhaul is needed, keep oil changed reg and just drive it
3answers
Need to know how to reset the change oil light on my 2002 aztec
If you have the Driver information Center then you just select engine life cycle and hold down set button, otherwise You turn the igniton on, pump the pedal 3 times within 5 seconds, the change oil light should start flashing indicating it has been reset.
Dash board light indicator
water light check coolent lvl in resavore
Engine coolant indicator light
try turning the key half way but dont turn on the car and hit the gas pedel three times
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
