Question about HP Compaq Presario 2200 Notebook
I need to know the steps on how to enter the computer´s BIOS and disable Hyper-Threading.
    Master:
  • 388 Answers
Try F9 or F2 when you first boot up look through all the sections it could be any where its depends on the make of comp or bios version.
Posted on Oct 08, 2010
Enable hyptreading
Hyper-threading is technology available on some Intel processors. If your process and motherboard are hyper-threading, you can enable to option in your Windows operating system. Hyper-threading allows your processor to perform multiple operations at once. Hyper-threading is used on multi-core processors and will share the workload among each core.
Restart your computer and repeatedly press the "Del" key or the F2 Key to enter BIOS this will vary depending on your computer and BIOS Press "Tab" to highlight "Main" then use the down arrow key to select "Hyper-Threading-Technology" then press "Enter". Select "Enabled" then press "F11" to exit and save changes. Your computer will now restart with hyper-threading enabled. Click "Start" then "Control Panel" and double-click "Device Manager". A window will appear showing your computer's hardware devices. Click the "Processors" drop-down menu. Right click one of your processor cores then click "Properties". Confirm hyper-threading is enabled. Hope this helps.
Jan 01, 2013 | Lenovo IdeaCentre B320 7760-2SU All-In-One...
How do you enable hyperthreading on msi 661fm
You will need to enter the BIOS by hitting delete key during POST.
Then navigate to tab System settings.
Locate the Hyperthreading field name and set it to enable.
Save setttting and exit.
Please take the time to rate my expertise, by rating this solution, its the thumbs up on the top right hand side of this solution.
Thanks
Nov 02, 2010 | MSI 661FM (ms-6540gbb-010) Barebone
Hyper Threading - How to?
right when the computer starts to boot up when you turn it on press F2 for the BIOS menu. a menu should pop up go to the correct category for what your looking for. there should be an option in the BIOS somewhere to disable/enable hyper threading.
Mar 05, 2010 | HP Compaq d530 SFF PC Desktop
Laptop will not accept operating system. was not working properly so i erased the operating system now it will start the setup for operating system then freezes on 99%.
Hmm, Theres a possibility it could be the disk, it important to take step by step procedures for example. Try another disk .. No? maybe try another CD Drive or the other possibility is a problem which i had, in my bios i set Hyper-threading on and changed buffer levels from 128 to 256mb on the video for example. For some reason was not allowing a new install. Removed CMOS Battery (on board) reset bios defaults and whack in a new disk. Let me know how it goes!
G
Feb 19, 2010 | Compaq Computers & Internet
Does it support hyper threading tecnalogy
Hi:
The answer is : it depends! There are several versions of your motherboard, and here is the cpu support for the latest version:
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=333&MenuID=69&LanID=9
You can find your motherboard version, and visit the support page and know for sure, though.
Jan 30, 2010 | EliteGroup P4VMM2 Motherboard
Intel(R) Pentium(R) 4 CPU 2.80GHz
The processor you are talking about is a single core processor capable of Hyper Threading. (HT).
When you allow hyperthreading in the BIOS, Windows will show 2 ghost processors in the device manager.
If you are authorized to acces the BIOS setup,,enter the setup and look for HT or hyperthreading. If you disable hyperthtreading in BIOS, you will only see one processor in device manager.
Besides, if it is a dual core the BIOS must know.
Look on the case of the computwr where the Windows logo apperas, you may find mentioned :With HT technology. It used to be a boasting/selling mantra.
Hope it helps.
Sep 08, 2009 | Computers & Internet
S651m MB Problem,please
try disabling the l1 and l2 cache memory,video bios shadowing and turn off hyper threading.i have done it a couple of times and it works.
Apr 21, 2009 | AOpen S651M (918EM10S50) Motherboard
Processor Upgrade For An IBM Netvista 8307-73G...
If the physical size, and numper of pins is the same as your current processor, you can most definately upgrade. Hyper threading is enabled through the bios, but as far as I know it's not neccesary.
Swapping out processors is fairly easy, and when you buy a new one, it should come with extensive instructions and pictures showing you exactly how to do it. Good luck!
Mar 12, 2009 | IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB...
Trying to turn off hyperthreading
You need to get into your BIOS. Go to CPU information. Highlight hyper-threading and enable or disable. Save and restart.
Dec 04, 2007 | E-Machines T3504 PC Desktop
HP Compaq Presario 2200 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
