Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Trys to come on but then c3 lights on meaning no ignition, but replaced ignitor, whats wrong?
    Scholar:
  • 146 Answers
What is the model number of your heater they are not made by a couple of different companies and they have different symptoms to troubleshoot.
Posted on Oct 08, 2010
GE JGB920sec2ss: Igniters dont light up burners
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad.
When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner.
One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad.
Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure.
If you have any other problems please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Feb 10, 2008 | GE Profile Spectra JGB920SECSS Gas Kitchen...
My Amana GUI090B30B furnace will not ignite. The ignitor glows then the valve releases gas but the gas does not ignite. The ignitor goes out and the valve shuts after a second or two of trying to ignite...
Hello, it is possible that even tnough the ignitor is glowing it might be too weak to ignite the burners. I would cneck the resistance of the ignitor with a multmeter, should be between 40-90 ohms typically
Nov 28, 2011 | Heating & Cooling
My pilotless oven wont light it went out after food spilled in it. What can I do and what can be wrong
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 04, 2010 | Maytag Ovens
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Our burners light but when you turn the oven on you can smell gas. Can you tell me what is wrong
most of these will have the oven bake ignitor become weak and not ignite the gas when turned on.
you should see the bake ignitor try to glow orange but the gas will not lit to the burner.
without a digital meter to read the current, should be 3.2-3.5 amps then you wont know if the ignitor is weak.
you could try to just replace it and see if that fixes you trouble.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan oven ignitor glows but oven doesn't light. what are the steps to test the ignitor?
Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
An easy way to determine an igniter problem without taking current readings is to test both oven features. Since there is a separate igniter for bake and broil, and both are fed from the same gas source, if the broiler works, but the bake feature doesn't, you more than likely have a bad igniter.
Read through the information provided and let me know if you have any questions. I hope this helps you.
Jul 05, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Roper gas range and oven with electric igniter
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Nov 07, 2007 | Ovens
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
105 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
