Question about All Star Allstar 100004 Front Idler Pulley ARD2A
Allister access 3000 garge door opener decided that it didn't want to work anymore. There has never been any problems with it, but it just stopped working the other morning. The light comes on when you push the button(both on the house, and the car opener), but nothing happens. Both sensors are lined up and the light is lit on those. When you hit the open button, the gray box that is attatched to the opener, clicks. Kind of like it is sending the signal, but it's not getting where it's supposed to go. Or, the box itself isn't sending the signal to the opener.
Where can i find a manual for craftman garge door?
Probably needs an adjustment. I would check Sears website as they have lots of info there for products they sell. An operators manual should give you this info.
Jul 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Owners manual for allister access 3500 garage door opener
I will send you a link to download a manual. You need adobe reader to download. If you do not have adobe there is a patch there too. Thanks BB
http://www.bearcatco.com/helpgifs2/maindiagrams.html
Sep 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Hi, my name is allister. i have a problem with
Hi Allister...
Check for fuses and make sure that the speakers are solidly connected at both ends
I can suggest a repair place if needed
Mar 26, 2010 | Adcom GFA-5802 2-Channel Amplifier
I have a chamberlain garge door opener and I bought a genie intellicode outside remote access and can't get them to work together.
They will not work together. You need to get the keyless entry for your chamberlain garage door opener. Or got a wired system gd-1 from Domino
Oct 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door opener just stopped working out of nowhere
1st Check to see if the saftey beams on the door track (near the bottom of the door,,,,,one on either side of the garge door) are still aligned. If they were hit or missaligned the door will not function.
The LED lights on the sensors will blink if not aligned properly.
2nd. If that doesn't work them try resetting the opperator by un plugging it. Wait 1 minute before plugging it back in.
Hope this helps
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Doors won't open
Jakenju, I would bet that the rod from the outer door handle is either off at the handle or the door latch on the pass door. Mayhap exact same problem on rear door.
Aug 22, 2008 | 1997 Toyota RAV4
All Star Allstar 100004 Front Idler Pulley ARD2A Logo
403 people viewed this question
Top All Star Home Security Experts
Tom Chichester
Are you an All Star Home Security Expert? Answer questions, earn points and help others
