Dell "Inspiron 2200" PC Notebook
Problem for Dell "Inspiron 2200" PC Notebook
2200 Screen Barely Visible
By landworks on May 29, 2008
The screen went dark one day. I have a CRT Monitor hooked up and those images are fine. Any do it yourself quick fix options out there?
Same Problem
Nov 09, 2008
-   same problem with my Inspiron 8100. Screen turned black for couple of secs. occasionally for few months, then completely out few days ago. Rebooting would turn it back on, with a light reddish tinge in the lower left corner, and it would go out again within 10 minutes. One repairman said that it was the CCFL and not the inverter and would fix it for $130.
I'm using an external monitor for now, as an extension of the notebook screen; and have to drag windows from the notebook to the ext. monitor, a rather inconvenient process. In Windows xp, is there any way that I can make the ext monitor identical to the notebook screen, or use the ext mon as the primary mon?
-   tkjho
Best Solution
posted on May 29, 2008
Very Helpful)
pishta68
Rank: Wiz
Rating: 84%, 324 votes
I have done it for 6 bucks. if your adept with a screwdriver, you can take the panel apart and look for the heavy lines that go from the inverer (small long PCB that is usually between the hinges or on the side of the top cover) and follow them up to the top of the white screen plastic backing. peel silver tape off and lift up flap and youll see the long CF tube, very thin, like 2.5mm and as long as the screen is wide. Looks like a tiny fluorescent bulb. Remove carefully, measure the length and diameter of the tube in mm eg. 283/2.5mm and look up that bulb up on internet under CCF cold cathode fluorescent. they run about 5 bucks plus shipping. Youll need to solder the wires back on but that is easy for someone to do if you are not good with that. Just touch ends with hot iron and they will come off, put on the same way. All is not lost. If that doesnt solve problem, the inverter is bad and can be replaced easier than the tube as it just unplugs. Get model number off inverter and look up on Ebay or google, they run about 10.00 used. Bad inverter or lamp will still show an image with a flashlight held up to the screen.
Was this helpful?
Yes
No
Solution #2
Helpful)
agent 10708
Rank: Master
Rating: 78%, 38 votes
it sounds like you have already done the 'quick fix'. it sounds like the 'backlight' on the unit has gone out, and to replace one of those if the unit isn't under warranty is pretty expensive. it starts around 100 bucks and goes up from there. i have seen one be as expensive as 500 bucks including labor.
Was this helpful?
Yes
No
Solution #3
Not Rated)
freetek
Rank: Wiz  Dell Computers & Accessories  Expert
Rating: 85%, 2075 votes
The most of the cost will be in labor; there are several sources for the lamps:
http://www.lcdparts.net/agnCCFLlamp.aspx?gclid=CKnn1MSTzJMCFQoRswodMSw3hg
http://www.ccfldirect.com/lcdrepair.html
Was this helpful?
Yes
No
Popular Solutions for Dell "Inspiron 2200" PC
Questions and Unsolved Problems for Dell "Inspiron 2200" PC
Do you recommend Dell "Inspiron 2200" PC Notebook?
Answer
Answer
my dell inspiron 2200 plays no sound n after i installed a compatible sigmatel sound driver it says... (More)
Answer
unable to access e-mail keeps coming up session over.
Answer
i keep getting an error message that states the drive is not recognized. I installed a PETA enhanced... (More)
Answer
video and sound do not match
Answer
how do i restore my hard disk in my dell inspiron 2200, it's not booting up
Describe your PC Laptops problem:
Ask our Experts
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(646) 202-3935
Macbook LCD Screen Replacement $159 iPhone 3g...
NYCiPodDoctor 877-TUNEDOC (8863362)
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
