Question about Toshiba 100GB ZIF 4200RPM 8MB 8mm HDD1789 MK1011GAH 100 GB Hard Drive
SATA connection Is there a SATA converter so I can use this SATA HDD in My Toshiba M55
  • jmets May 30, 2008
    I need to use it in my laptop, the problem is the pin config.
  • Anonymous Jan 16, 2009
    I need a SATA adapter to ATA-6 for a laptop hard drive. 1.8 inch Toshiba MK1011GAH
  • 22 Answers
Do a Google search for "SATA adaptor for laptops". This should point you to available SATA to USB adaptors. Haven't clue how well they work, but they are out there
Posted on May 30, 2008
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
How Do I exactly make a 500gb sata hdd work with this p4m266a ndmx motherboard? It doesn't appear to have a sata port and using the sata compatible cable did not help. Thanks
if your motherboard does not have SATA, purchase a SATA - PCI card, they cost something to the direction of 10 to 20 $ and give you 2 to 4 or more SATA ports.
Feb 12, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Hdd detecetion proublem on 845 motherboard
845 chipset dont support sata devices and this is common problem that if unsupported device is forcefully bieng tried to work its goona happen sata support started from865 chipset u are lucky that ur hdd is getting detecting
Jun 11, 2010 | Computers & Internet
Just replaced the HDD in my Toshiba Satellite M55-S329 from a 100GB to a 320GB after the old HDD failed. Now after replacing the HDD, it does recognize the hDD but I get the error message "pxe-e61 media...
You have to change to boot order in the bios settings, it is currently trying to boot from a network drive, it needs to be set to the HDD you just installed.
Jul 27, 2009 | Toshiba Satellite M55-S329 Notebook
Sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Jul 22, 2009 | Hitachi Deskstar T7K250 250 GB Hard Drive
I need user manual book of my M55-3293, please.
Hello!
Your user manual is available from Toshiba here:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=1132280&coid=105484&soid=1083054&modelName=Satellite%20M55-S3293
Feb 17, 2009 | Toshiba Satellite M55-S3293 Notebook
Need motherboard for qosmio laptop. do I have to replace w/same
they make an ata to sata conversion cable that you can buy, look on the boxes of the hdd's most of them come with the converter that you need
Dec 03, 2008 | Toshiba Qosmio G15-AV501 Notebook
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Sata hdd not detected.
Check the bios to see if it made the pata drive primary. If it did the system will try to boot off of your backup drive and you could think that it is not seeing your sata drive. If that is the problem you must go into the drive configuration and make the sata primary.
Nov 21, 2007 | Toshiba Portege 7100 Notebook
Toshiba 100GB ZIF 4200RPM 8MB 8mm HDD1789 MK1011GAH 100 GB Hard Drive Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
