Question about Troy Garden
How to change oil on Power Mower - Troy Garden
  • 26 Answers
Hi bob--
The link at the bottom here has a good picture of what you should be looking for underneath the mower as far as drain plugs on power mowers go. At that website, just scroll all the way down to the photo of oil changes.
Please be sure you disconnect the spark plug before you do anything else to the mower. Also, once you locate the drain plug underneath the mower and you have it open, open up the dipstick or the oil fill caps on the mower and LEVEL the mower as best you can over whatever you're using to collect the used oil. This allows the most amount of used oil out of the machine. I like to add new oil to the fill cap until I see new oil pouring from the drain plug--but that's a little overkill!
After you've reinstalled the drain plug. Put the mower on level ground and start filling SLOWLY. Check the dipstick often--it is easy to overfill the crankcase, and then you will have to empty the excess oil and go back to fill again. Just take your time. Good luck.
--Hope this helps. If it does, please vote and comment. Thanks!
http://floridagardener.com/misc/tuneup.htm
Posted on Oct 09, 2010
  • joe Oct 11, 2010
    I went into better detail at this link. Hope this helps. http://www.fixya.com/support/t6353905-ca...
Oil is very thin
Hi, When you run a small engine it will need a thinner oil. Especially if you run it in a colder climate. Here are the basic rules when it comes to oil:
  • If you just bought a new mower or other piece of equipment, add oil before you start the engine. These products are shipped without oil. Even if the product is delivered to your home fully assembled, check to be sure the engine contains the right amount of oil.
  • Check the oil in your mower, pressure washer, portable generator or other outdoor power equipment each time you use it. Do this when the engine is cool. If the equipment has a dip stick, pull it out and wipe it off, then reinsert it all the way and pull it out again to check the oil level.
  • You should change the engine oil in your outdoor power equipment after 25 hours of use. If you are working under dusty, hot conditions, change the oil more frequently.
  • Don't overfill the crankcase when adding oil. Too much oil can damage the engine.
  • Briggs & Stratton offers oil specially formulated for your mower and other equipment. Our 100% synthetic oil is an all-season oil blended for all small engines. Briggs & Stratton Lawn Mower Oil is formulated for 4-cycle air-cooled engines, and 2-Cycle Ashless Oil is a premium ashless oil with gas stabilizer made for use in 2-cycle air-cooled engines.
Jan 03, 2012 | Coleman Powermate Premium Plus 6250W...
I put too much oil in the mower over the past couple months. Two days ago the mower began steaming. I shut it down immediately. Today I did an oil change and cleaned the mower up but after I started it,...
If you already changed oil and it is at proper level on dip stick let it run for about 5 minutes to burn out any excess oil in cylinder, if it continues to smoke you probably blew a gasket or seal on engine.If that is the case you are looking at buying a new mower unless if it under warranty or you have a cheap mechanic.
Aug 30, 2011 | Toro Lawn Mower With Toro Power Tools
Want to change oil. Is the oil drain under with a 3/8 socket drive drain plug ?
Hi lfancisco...
Yes the oil drain plug is under the mower, normally a square plug,socket drive to remove to remove the oil from the machine.
Please take time to rate me...Free answer
May 16, 2011 | Toro Power Lawn Mower
Where is the oil plug for changing oil in the Toro recylcer 700 series. I can't find it anywhere
Hi marybasrai...
Look under the mower to find a square plug/allen key plug and remove that plug will allow you to drain the oil from the mower
Free answer, Please rate me
May 07, 2011 | Toro Power Lawn Mower
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
I have to prime the toro mower every time I empty the bag to get it to start?
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Oil Drain Plug Location
that is the drain plug sometimes hard to get loose but should come out it is in bottom of engine above blade.
May 07, 2009 | Toro Lawn Mower With Toro Power Tools
Trouble starting the mower
check the oil level , oil change?, spark plug check/clean. air filter check. is the deck clogged with grass? then let me know how it starts
Mar 20, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
110 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
