Question about Jacuzzi Home
Jets will not operate - Jacuzzi Home
    Problem Solver:
  • 16 Answers
If you depress the switch and hear the motor turn on, there is a break in the plastic tubing that delivers the air to the jets. If you depress the switch and the motor doesn't come on, there is possibly a problem with the switch, the motor, or maybe even the electrical circuit for the device is not complete.
I hope this helps you solve your problem.
Posted on Oct 08, 2010
2002 Arctic Cat 375 starts but won't continue to run?
Try running it with the choke partially on. Most Arctic Cats are jetted for higher altitude operation from the factory and need a larger main jet installed. Partially closing the choke will make it operate until you can get the carb rebuilt with a larger jet.
May 09, 2017 | Cars & Trucks
My car is not idling!How do I know my idling jet not kicking in
the idle jet is a fixed jet size and an integral part of the high speed performance
fuel is sucked through the jet into the manifold at idle but at rpms that circuit becomes empty of fuel and the air that is sucked in atomizes the fuel in the emulsion block of the carby and helps with burning of the fuel
so what you have indicates a blocked idle jet or if the carby has a idle jet solenoid to prevent engine run on when the ignition is turned off , check the operation of that solenoid
Jan 02, 2017 | Motorcycles
Where can I get a manual for model 0078551
I was able to locate a PDF file for the DAYTON Convertible Jet Pumps and Systems/Operating Instructions & Parts Manual...I located it here: http://www.grainger.com/ec/pdf/Dayton-Convertible-Jet-Pumps-and-Systems-OIPM.pdf
Hope this is what you were looking for?!
Jan 07, 2016 | Utilitech 1-HP Convertible Jet Pump...
How many jets does the 380 have that may need to be cleaned, I see 3
It sounds like you have a clogged drive turban jet or an internal hose has popped loose. I normally tell people to double check the backup valve to verify that it has been installed the right way (widest part toward the wall,)
There is a total of 6 jets, three vacuum jets blow debris into bag, one thrust jet bows water out of the nozzle on back of unit, one drive jet that operates the drive gears and one operates the sweep tail.
It is best to disassemble down to the "water management system" listed above and rinse well, shaking it in all directions. Any small debris can clog the jets, including ants!
Feb 24, 2013 | Polaris 380 In Ground Pool Cleaner
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Jet storm critical error:boost:filesystem::path: invalid name"/Jet Storm savegames"in path: "D://Jet Storm savegames/jet_save000.bin"
Rename the folder "D://Jet Storm savegames/" and create a new one with the same name. Try after that.
Mar 05, 2011 | Computers & Internet
Not all jets work and the ones that do are not strong.
Most jets are adjustable for pressure. Most can be adjusted by turning the jet left to right. If the jets are not adjustable and the pump is operating normally, it would be best to call a certified repairman in to assess the problem.
Aug 26, 2009 | Home
Kohler K1338 spa tub controls messing up
no it is not damaged. that is the way it is operated. it always resets to the bottom jets first.
Mar 04, 2009 | Home
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
