Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Pump will not stay running. motor gets warm. motor shuts down after running for about 10 to 20 seconds.
Check the voltage at the pump while its running. If the electric feed line is too long for the guage wire,
voltage drop will cause the motor to overheat and switch off.
Posted on Oct 08, 2010
What stops a fuel pump from working ,on a grand am se v-p6 3.4 motor ? I did'nt let it warm up the other mournin g , got down the road and it shut off driving.
A fuel pump does not need to be warmed up to work. They just wear out. If its the fuel pump that's the problem it will have to be replaced.
Jan 08, 2017 | Pontiac Grand Am Cars & Trucks
2009 Honda shadow starts bu will not stay running
You either have a fuel delivery problem or a thermal condition that kills the spark when igniter gets warm. Look at fuel pump, filters, etc. Also make sure that there are no exhaust restrictions that will shut down a motor.
Jun 23, 2015 | Honda Motorcycles
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
Runs for about 15 secs and then stops
Let's getdown to basics. You have already done the most basic, and time saving task- that being setting and monitoring the pump pressure. What youmust troubleshoot:
  • is the problem fuel related? or
  • is the problem electronics related?
To find outyou must eliminate all fuel related possibilities because there is not much wayto successfully troubleshoot the electronics without access to DESA'sdiagnostic tool- HA1170.Keep inmind that the ignitor only stays red for 5 seconds- just long enough to startthe flame- the flame must perpetuate itself. If at ANYTIME there is a momentaryflameout condition (or off-color flame condition) the heater will shut down.The photocell's job is to monitor the flame condition. If the photocell doesnot see a flame that it likes, then it will shut the heater down.If thisheater was in my shop and the customer described the problem, the first thingthat I would do would be
  1. check the pump pressure- this is ALWAYS the first step.
  2. shine a flash light into the fuel tank- inspect for water droplets in the tank
  3. check for possibilities if a restricted fuel filter
  4. check for possibilities if a restricted nozzle
  5. with soapy water check for air leaks from the pump - all the way to the nozzle.
  6. If all of these check out then remove the top cover. If the heater runs fine with the top removed- replace the nozzle. Desa recommended annual replacement.
  7. The motor has an internal heat sensor. If the temp on the motor exceeds the safe level the sensor will shut the unit down. There is usually a pattern. The heater will run for an extended time, shut down, re-start, but the runtime is short. Let the unit cool and the pattern repeats itself. Feel the motor after shutdown. It should only be warm to touch. If hot, remove motor and bench test.. 2 possible causes- broken or grungy rotor or internal problems in the motor.
Troubleshooting tipsIf theproblem persists, then replace the control board & photocell.
Oct 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My 95 tahoe starts but dont stay on. Fuel wont stay pumping from tbi. Just swapped a motor from 80's camaro. Was running real good in box chevy perfect. Now fuel wont stay flowing out of injectors. Already...
did you install the oil pressure switch origional to the tahoe? The tahoe uses a low oil pressure shutdown, instead of an inertia switch to shut off the fuel pump in the event of an accident. If the pressure circuit does not close within 3 seconds after the engine starts the fuel pump shuts off. This is in case the truck is on its side or upside down the pump will shut off.
Aug 19, 2010 | 1995 Chevrolet Tahoe
Pump lost its prime ran for several hours dry motor runs and pumps water gets very hot and shuts down after about 30 seconds
ITS GOING TO NEED SERVICE. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, USE YOUR ZIP IN YOUR SEARCH
Aug 18, 2010 | Pool & Spa
Started up my acura tl 2000 and started to hear knocking and shut off
Check oil level and oil pump. Oil pump light should turn off after a few seconds after start up. If light stays on for more then 3 second shut off and do not drive or run motor.
Jan 12, 2010 | 2000 Acura TL
1990 full size blazer starts fine idles then dies
sounds real easy either a bad idle air control solenoid or more likley a blown throttle body gasket. to test fro a blown gasket, with engine running and cool spray carb cleaner or brake cleaner around base of tb were it bolts to intake. when it hits the bad area, should idle down and be normal for a second or 2. iac is possible,try this first since its so common and let me know
Aug 26, 2009 | 1990 Chevrolet S-10 Blazer
Have a 93 camary 4cyl, the motor shuts down when warmed up
First, see if it loses fuel, or spark when it dies.
Aug 05, 2009 | 1992 Toyota Camry V6
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
279 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
john h
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
