Question about Whirlpool Washing Machines
I have a topload machine that been working quite well up til yesterday. Put in a load of laundry and started the machine, it would go through the wash cycle with no problem, but stopped when it reached the rinse/drain cycle. The machine was working perfectly the day before. I reset the machine to the final wash cycle but still nothing when it gets to the rinse. Advice?
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description it sounds like a lid switch problem.
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Oct 08, 2010
Ran one load of laundry in washer, started another and the unit just beeps 3times and I push to reset but lid won't lock or start cycle. I tried moving dials to wake up machine but got no luck
My GE top loader has a little "finger" on the lid , when lid is closed it depress a switch inside a little hole , Now YOU with a wood pencil you turn machine on and press the little switch inside the hole, it may have dropped too low for the "plunger". the washer should start. now tighten the screws for that switch.
Jun 03, 2015 | Frigidaire FFLG1011MW Gas Washer/Dryer...
Washer would spin dry but the clothes is still wet
Sounds like your transmission is starting to go bad. It is not creating enough power to spin fast enough to dry the clothes. A new transmission is going to run about 400 I would start shopping for new machines. Do light loads of laundry til you get a new washer..
Jul 14, 2011 | Whirlpool Washing Machines
I have the Whirlpool Topload Cabrio washing machine and it will be a year old on Jan. 15, 2011. It is really starting to stink up my laundry room. I have run the wash cycle through with distilled vinegar...
Here is what I do. I run "Tide Washing Machine Cleaner" thru the washer first with HOT water. Then, I recommend running a rinse only with hot water & bleach to rinse the washer out really well and don't forget to leave the lid opened when the washer is not in use.
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Fisher and paykel toploader will not start!
quite likely the motor controller has died, which is situated underneath the control panel.
May 31, 2009 | Fisher and Paykel GWL11 Top Load Washer
GHW9100LW1 W/POOL WASHER
if dorr does not lock then the fault is door interlock
Dec 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
