Question about Lexmark Wheelwriter 5 Series II Typewriter
Won't boot. all right hand lights are on solid and it sounds like there's a motor running.
  • Lexmark Master
  • 3,594 Answers
The carrier belt may be off or broken.
DickyO
Posted on Oct 18, 2010
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
My front of my car vibrates like crazy everytime I accelerate and turn right but when I let off the has it stops
Sounds like maybe a busted motor mount or transmission mount, or a worn out cv drive axle.Look under the front of the car at the drive axles there is 4 rubber boots 2 on each axle inner boot and outer boot.See if one or more of the boots is torn or split.
Jan 20, 2013 | Cars & Trucks
Won't boot up and fan not running
Sounds like a dead battery or power supply or both...check for a light on the power supply to prove it's connected.
Jan 09, 2013 | Sony VAIO VGN-NR285E/T Laptop
My right rear turn signal stays solid, won't blink, in the vehicle the right blinker light blinks excessively fast, I have a 1999 surburban
Sounds like a bad ground to me, although i am no expert.
i would be checkinh all connections and take it from there, a little wd40 might just solve it short term.
Nov 26, 2011 | 1999 GMC Suburban
I have a Kupa/KP36 that is making noise but the bit is not rotating. I have check the cord for power, tried different outlets. Unplugged hand piece replugged it in changed bits and still the same result....
Sounds like the chuck holder is already worn and needs replacement.
If the motor still runs but the drill bit won't turn the problem would be the chuck adjuster( the one that holds the drill bit and tightens it ).
If the motor does not turn but there is a whining sound the problem would be the armature bushing ( it is inside the motor which the rotor/armature rotates). The armature does not turn anymore.
Fuse is out of question because the motor still have some power. Check also the motor brush.
Disassembling it requires to unscrew all the screws on the side and carefully remove the side cover, you can clean it and dust it off.
Hope that helps you out!
Jul 07, 2011 | Drills
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
Lexmark Wheelwriter 5 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
