Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have the gs5shaxntoo type 26ssa Ice maker not making any ice
fridgetech
  • 473 Answers
SOURCE: Ice maker not making ice
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge.  Also, make sure the fill tube to the ice maker isn't frozen up.  There should be a 3 digit # in front of the 52554100.
Posted on Oct 18, 2007
SOURCE: ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
Posted on Dec 20, 2007
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
  • 3741 Answers
SOURCE: Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Posted on Aug 29, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Ice make will not stop making ice
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Jan 06, 2017 | Refrigerators
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Oct 05, 2016 | GE Refrigerators
It will not shut off. Just keeps making ice ?????
Mar 23, 2015 | Refrigerators
Why won't the ice maker shut off even when I shut off the switch? The ice maker does not use a shut off arm or lever
Sep 05, 2014 | Kenmore Refrigerators
Ice maker won't shut off
Jan 26, 2014 | General Electric GSH25JFX Side by Side...
I have the same problem
Yes it is a simple depression contact switch that pops out . Sometimes with the gentle help of a screwdriver. Install is same in reverse.
Jul 24, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gold Side by Side Refridgerator GS5SHAXNTOO "Not" making Ice
this is a very broad problem. you have issues with your ice maker. it could be the solenoid that supplies water to it. it could be turn off, it could be the laser sensor malfunctioning. it could be the receiver of the laser. it could be the gear that harvest ice is froze up. or the heater to melt the ice if it has one has gone bad. or it could just be a stuck ice that would not come out of the ice maker.
you can remove your ice maker, thaw it up if there is ice in the tray. then install it back and observe.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Whirlpool GD5SHAX Side by Side...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
88 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
