Question about Garden
Can i get a needle and seat kit for a 5HP b&s aeiens tiller in Australia. cheers Bruce
  • 3,740 Answers
Bruce use this page to locate a dealer in Australia:
http://www.briggsandstratton.com.au/bdealers1.html
You will need your engine type, model, and serial nunmbers tht are usually stamped into the air shroud.
You can use this page to match up your Float-Valve needle and seat part number:
http://www.jackssmallengines.com/carb_parts_bs.cfm
Then call the dealer in AU using the link above to locate one by part number.
It is small enough to be mailed in a regular post envelope.
Thanks for choosing FixYa,
Kelly
Posted on Oct 08, 2010
Gas going into crankcase on my 5hp small engine
leaking float needle and seat
clean the needle and seat out or replace it
Nov 12, 2016 | Air Tools & Compressors
What is a 1969 troy built tiller worth in great shape?
I sold my pony 5hp in good shape in Canada for 275.00. At that price I had a number of people wanting it. Cheers to you!
Sep 21, 2014 | Troy-Bilt Garden
Tecumseh 5hp feul bowl leaking
Tecumseh rebuild kit number 63021B comes with a needle and seat, bowl gasket and bowl nut gasket. Should solve your problem.
Nov 08, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Trying to find a maintenance manual (exploded view of transmission) for a craftman rear tine tiller (may have been made in Canada), with 5hp Brigs & statton (1985 from motor serial). The tiller serial...
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.Try 917. as the first part of model #.
RGS
Mar 17, 2011 | Craftsman Garden
I have a yard machine 5hp 22" snow blower. The
TRY PUTTING SOME SEA FOAM IN YOUR GAS AND LET IT RUN AWHILE MAY HELP.
Sep 25, 2017 | Yard Machines Garden
I have a 5hp B.& S. horizontal crankshaft engine that has started to flood badly. I suspect that the needle valve is stuck open but I don't see it. The carb. is mounted on top of the gas tank. How...
On models with the carburetor mounted on top of and part of the fuel tank do not have a float and needle valve. make sure the air cleaner bolt/screw is all the way in or else the engine will **** fuel through the threaded hole for it. If this is a different kind of carburetor let me know.
Jun 07, 2010 | Garden
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
May 29, 2010 | Craftsman Garden
We have a snow king 5hp/22'' mtd snow blower that we cant get started. We have cleaned the spark plugs but it seems the fuel is not getting to the plugs to ignite the engine. is there a particular position...
key on choke on....prime it..start.
see if your getting spark first...if you are most likely you have a dirty carb and it needs cleaned well (build up from old gas will make them gummed up and not work at all). try that and then try to start again
Feb 06, 2010 | Mtd Products Yard Machines 158CC Tiller
GAS OVERFLOWS WHEN GAS TANK VALVE IS TURNED ON.
If you don't hear anything inside the float, it has to be leaking past the needle and seat. Replace them. Dwain
May 27, 2009 | Troy-Bilt Garden
The tiller starts but will not stay running after a few minutes
that's a B&S 5hp motor
need a fuel diaphram most hardware stores carry small kits for small engines
manual page 65
Mar 22, 2009 | Mtd Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
