Question about Xerox WorkCentre M-24 Color Copier
Hi - I have a Xerox Workcentre 4250 Printer/Fax and keep getting error code 22-504 (Paper Properties Mismatch). The tray has the correct paper size ... what to do? All the pending jobs are idle ...
  • 45 Answers
Check the print settings on the documents that are idle; they may be an off size rather than the standard and you may have to fake out the printer by "resetting" the paper size to the size of the print jobs; this sounds off but works in may cases. To reset the papersize, pull out the tray and put it back in, manually set the page to whatever it is calling for.
Please let me know if this is not clear,
Good Luck!
Posted on Oct 08, 2010
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Display says paper size mismatch.
Check the paper trays, they have a slide movement on them
at the back of the tray their might be some tabs to move for the right positions of the paper size,
Check the reports menu button on the console, make sure the trays say it has the right paper installed for that tray. Each tray has to be told what type of paper it holds.
The machines needs to be configured in the settings menus.
Good luck.
Jul 22, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size Mismatch on Xerox workcentre 4118 i cant print
Most likely the tray setting has changed, Here is what to check.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required tray is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required paper size is displayed, and then press the [Enter] button.
  5. Press the [Stop] button to return to the Standby mode
I am sure you will find one of the tray settings to be incorrect.
If not, click on the printers on your computer, Right click the 4118 and look in the printer properties. One of those settings may be off.
More likely is that the machine settings have changed for whatever reason.
Jul 07, 2010 | Xerox WorkCentre 4118 Network Kit...
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
M20/Ms0i WorkCentre display "Paper Size Mismatch"
the settings on the print driver and the machine do not match.
  1. ress the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  3. Press the [Left] or [Right] arrow button until the required paper tray is displayed; either [Tray 1 Size], [Tray 2 Size], or [Bypass Size].
  4. Press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until the paper size loaded in the paper tray is displayed.
  6. Press the [Enter] button to save the setting.
  7. Press the [Stop] button to return to the Standby mode.
Jan 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
When trying to print from computers the message comes up paper size mismatch Xerox M20i
double check the paper setting and margins set up on your computer.
check the printer properties
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M-24 Color Copier Logo
736 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
