Question about Craftsman Gas Mini - Tiller/Edger
Carborater problem - Craftsman Gas Mini - Tiller/Edger
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Spark plug is new & cleaned carborater it ran for about 2-3 sec & quit.It acts like it isn't pulling gas. This type lawnmower has plastic carborater and doesn't have a diaphragm.Any suggestions?
If you can find the fuel jet take it out and clean it. If there is dirt in the jets there will be no gas get to the carb. I blow mine out with an air line from an air compressor. or get a real fine wire and put through the holes. don't injure the jet or it won't work.
Apr 07, 2016 | Garden
Geting gas to carborater but not to sparkplug
Check the Jets in the Carborater they my be stopped up also check the float it could be stuck as well
Sep 20, 2015 | Honda Cars & Trucks
Craftsman weedwacker
If yiu remive the cap on the fuel tank and kook inside you will see one line only just enters the tank, this one giesto the orime bulb, tge ithet gies ti the carb inket.
Aug 02, 2013 | Garden
Fuel not getting to carborater
then it is fuel related make sure the fuel shut off is turned on if fuel was left in it for a long time dump it out and try fresh fuel then take apart the carb and clean it completely
Mar 26, 2012 | Husqvarna Garden
Truck will run only when i pour gas into carborater once it uses gas in carborater it stops firing
This sounds like a problem with the fuel pump. I would suggest that you check the fuel pressure. it should be 60psi. If not...fuel pump most likely the problem.
Feb 02, 2011 | 1999 Ford F250 Regular Cab
Back fires through carborater at high speed
mcdevito75 here, Either you have a worn / burnt / cracked intake valve, worn timeing chain / belt or the ignition system needs to be checked and adjusted. The shop has the tools and equipment to help you out.
Oct 25, 2009 | 1985 Nissan Pickup
Will not start
Sounds like dirt in the carborater. I just took my carborater apart to clean it and I can't remember how to put it back together. If you try the same thing, Please take some pictures of it first.
Sep 02, 2009 | Yard Man Mulchinator QuickShift BlowerVac...
Carborater gets stuck on my 1989 jeep cherokee pioneer
The 1989 Jeep did not come with a Carb it was throttle body injected and the motor should be a 4.0. let us know what motor it is.
Feb 28, 2009 | 1989 Jeep Cherokee
Not sure what Carborater adjustments need be?
while your running it play with the screws, until it sounds steady and runs with out stalling
Dec 20, 2008 | Toro Blowers Rake and Vac - Electric...
Craftsman Gas Mini - Tiller/Edger Logo
206 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
