Check your power board #67001360, check for 110v in, and 12/24VDC out. If no DC volts out this is your problem. Should be JP11 small board middle of the electronics compartment...Check your power board #67001360, check for 110v in, and 12/24VDC out. If no DC volts out this is your problem. Should be JP11 small board middle of the electronics compartment...
You can't post conmments that contain an email address.
https://www.ebay.com.au > itm
Type 165L Fridge Freezer. This Mishto Portable Fridge is perfect for outings, keeping your food and drinks chilled. It has a practical design, ...
If your Samsung fridge is showing a plug-in sign on the display, it usually indicates that the refrigerator is not detecting a power source. However, if the cooling is normal, it is likely a display error.
To clear the display error and restore normal settings on your Samsung fridge, you can try the following steps:
Unplug the fridge from the power source and wait for at least 30 seconds.
Plug the fridge back into the power source and check if the error message has disappeared.
If the error message is still there, try resetting the fridge by pressing and holding the power freeze and power cool buttons simultaneously for about 10 seconds. This should reset the display and restore normal settings.
If the error message persists despite trying the above steps, it might be an indication of a more serious problem with the fridge. In such cases, it's best to contact Samsung customer support or a certified technician to diagnose and fix the issue.
The blue led dies because the power source dies: it detects a big short on one of its outputs and shuts down to protect itself automatically. Since apparently it's a very big short and you just had to replace the bulb then the faulty part is the ballast board (the one that powers the bulb): when the bulb failed it has generated a power surge that fried it.
Replace the ballast and verify the power source board: if you're really unlucky when the ballast got fried it has in turn damaged the power board.
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
