Question about Dell OptiPlex 330 Desktop Desktop Computer
I have a new printer plugged into the computer via the usb port, but the computer isn't picking it up. The drivers are installed, but the computer won't pick up the printer
    President:
  • 1,768 Answers
1. unplug the device via the USB cord and then connect it again
2. Shut down the PC an restart it after 10 seconds
3. After restart go in to the print setup and see if you have the printer device showing
as a usb printer / it also should show in the task bar on the bottom right as USB devices
installed.
4. If you have Windows 7 it may be that the drivers may need to be up graded
they may be in Vista or Windows XP drivers. There for the Operating System may not
recognize the device. Check your printer instruction manual for the correct requirements
Posted on Oct 07, 2010
    Master:
  • 388 Answers
I would try plugging in another usb device to see if the connecter works or try another port.
falling that try windows update.
Trying to add a printer to computer via usb 2.0 printer cable
plug your printer into any usb input point on your computer
found new hardware wizard should start or you might have to do it manually
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Feb 14, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Hi I have a new brother printer and it was working fine. I have gone to use it again and it keeps saying the printer is offline...yet I have registered again and everything is the same. Help
check that the printer cable is inserted fittingly, on the computer and on the printer, if alright,change the port from which the printer cable is connected,am assuming it is usb. if still not responding, turn off the printer, reboot the computer, and turn it on, if it fails, unplug the printer from the computer and uninstall the driver. reboot the computer and reinstall, while installing, it may prompt you to plug it in. if it does not, do not worry, just plug the printer cable after the installation is through, the computer should recognize a new device and go on to auto install, if it does not, then you have bad usb port port or controller drivers. to be certain, plug any other usb device onto the port(s), if positive, buy a new usb card and install on computer and connect printer
Oct 17, 2010 | Brother MFC-7440N Laser Printer
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Tried to connect my NX6310 to my printer which is a HP All-In-One series 6300 BT. Printer will not work and I used the cable USB port to USB port and picked up new drivers, Microsoft Professinal, XP
The trick with windows XP, most of the time is to install the drivers first and wait for the software to ask you to plug in the printer. Try removing the printer from your printer's folder if windows already tried to install it, reboot when it removed, then install the device drivers/software first and when asked...plug in the printer.
Nov 18, 2009 | Computers & Internet
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Computer recognises printer but print requests not actioned
that happened to me with my cannon ip4300 so I installed the driver again so I had 2 drivers installed on the computer. The computer named the seconed instalation cannon (2) .
number 2 worked the first didnt.
so used number 2.
later deleted number 1 .still all ok
wierd but worked.
david267
Jan 27, 2008 | HP LaserJet 4L Printer
Printer not configurating with computer
Two problem that occur. You plugged in the new printer before installing the software. If you have XP it will go and install it with it's drivers. Your printer wants it's own drivers. A second problem I've seen is having too many devices plugged into USB ports. If the software was installed properly, remove non-needed USB devices and re-boot the computer. If the printer works, look into purchasing a "POWERED" USB hub. They cost between $5-$25
Mar 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Dell OptiPlex 330 Desktop Desktop Computer  Logo
24 people viewed this question
Alun Cox
