Question about Keurig B100 Coffee Maker
Our coffee pot will not release water into the k-cup unless you pull the hose off of the clear plastic filter looking mechanism. (maybe check valve) this is on top of the mechanism that punctures the k-cup. Can you order another one of these parts? If so where?
    Champion:
  • 248 Answers
Web search-keurig b100 coffee maker parts
Posted on Oct 08, 2010
Water gets stuck in the filter
Inspect the strainer basket's valve to make sure it is not blocked and working properly. You should be able to test it in the sink, fill with water and push the valve up from underneath. Tap the valve a few times to loosen any debris that might be blocking it.
Make sure the pot is fully in place on the warming plate. The lid must align properly with the strainer basket to open the valve adequately. If the pot lid is not touching the strainer basket valve, you may have the wrong pot or the strainer basket is not seated into the coffeemaker correctly. Check for obstructions underneath the strainer basket. Then, make sure the rounded projection aligns with the notch in the coffeemaker near the reservoir.
Jul 10, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Slow process
I had the same problem with my Mr Coffee ISX23. I took it apart and found a little chunk of something was stuck in an in-line check valve from the fresh water reservoir to the heater thingee. After disconnnecting the hose from both ends it slid out of the hose I pulled the little black (maybe rubber) thing out and reassembled it. Works great. Be sure to replace the check valve oriented the right way. I tested this by blowing on it.
Nov 25, 2011 | Mr. Coffee Coffee Makers & Espresso...
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
The water and coffee grinds sits in the filter, does not drip into the pot
Most modern coffee pots have a feature in them to keep you from spilling coffee all over the place when you want to take a cup of coffee before they finish brewing. It sounds like you are having some issues with yours.
Basically, the way they work is that there is some sort of gasket (rubber disk) that has a lever/spring mechanism that plugs the way out of the filter basket when there isn't a coffee pot under the filter basket. They are designed so that the lid of the coffee pot pushes up on part of the mechanism and forcing the little gasket open. (You can generally figure it out pretty easily by fiddling with it.) It sounds like you may not be assembling the lid on the pot completely (this model has a lid where the dome sticks up) or may be missing the lid all together. It's also possible that a piece of packing material may be clogging this or the gasket could be stuck shut, maybe with dried coffee.
One sign that the assembly is working properly is there is just a little bit of resistance (not very noticable) when you first start putting to pot in place and it makes a clicking/thunking noise when the pot fully seats.
Sep 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Coffee maker making noise but not releasing coffee
Hello k_alderman
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Mar 27, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Our hamilton beach 10 cup brewmaster coffee pot which is programmable will not brew more than one cup even thow you want the whole pot to brew. we cleaned as reccommended. any more help with this problem...
If you have tried tried to clean the unit according to the manufacturer and the problem still persists you may have a something that has become lodged in the check valve. Unfortunately, unless you have a special screw driver required to remove the two anti-tamper screws fastening the bottom cover to the unit, and are willing to void the warranty if still covered, you will not be able to service the unit yourself. If so, before preceding make sure the unit is unplugged from the electrical outlet and any water remaining in the holding tank is removed by holding the unit upside down over a sink. Caution water may still be hot.
With the bottom panel removed locate the rubber hose connecting the heating tube to the bottom of the holding tank. Important... Before removing the hose be sure to make note of the orientation and position of the check valve as it must reinstall in the same direction and position in the hose. To remove the hose slide both clips toward the check valve and remove. Note that the clips are of different sizes. The large is used on the tank end, the smaller is used on the metal heating tube end. With the hose removed, carefully slide the check valve out of the tube and remove any debris that may have become lodged in the valve. You may need to remove the plastic ball from the three prong holder to do so. Do not use any sharp metal objects to remove the ball that could damage it. Once cleaned reassemble the valve and place it back into the hose. Reattach hose making sure not to leave any kinks in the hose and that the check valve is properly installed in the same direction and position in the hose as before. Besure to reinstall bottom cover before returning the coffee maker to service. To prevent electrocution.. Do Not plug unit in with bottom cover removed.
Feb 25, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Leaks while filling
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Sep 26, 2008 | Mr. Coffee FTX49 12-Cup Coffee Maker
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Keurig B100 Coffee Maker Logo
162 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
