Question about Bose Lifestyle 28 System
Hello i just turned my system on i have video but no audio , it say speakers not connected
Any luck? I have just been to a customer who has the same problem!
Posted on Oct 23, 2010
Hi we just purchased a KA240H we didn't realise it dose t have sound can l hook up speakers to it
The Acer KA240H is a monitor with VGA and DVI video inputs. Since neither of these carry audio, you'll need to connect the speakers to the video source. If your source is a computer, you can use any speakers with a 3.5 mm cord or that can use an adapter to the 3.5 mm stereo plug. These can be headphones, 2 connected speakers with the control on one of the speakers or 2.1 systems (subwoofer + 2 speakers). (On some computers, you may be able to use surround sound speaker systems. However, all of the connections to the source will use 3.5 mm plugs. Check your system for the audio outputs.) Some systems may support blue-tooth audio speakers.
If your source is another device, you'll need to make sure that you have the appropriate audio connections for the device and speakers.
I hope this helps.
Feb 15, 2017 | Audio Players & Recorders
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
I plugged in my Altec AP3 Speakers to my computer running windows 7. It does not play. i get sound directly from my PC (it had sound prior to plugging in speakers) however the Altec speakers have no sound
Hello
You haven't specified from which computer source you connects this device with. If it is from the audio out socket of the PC, your PC's audio card [or onboard audio] dirive hasn't been installed yet. Unlike WinXP, Win-7 haven't all driver software in its driver cab when it is installed. If onboard sound should energize, the mother board CD should be loaded. There is audio and video drive [normally NVIDIA] drive should be installed. Anyway, you have to install the dirve. Now it disabled. Go to the hardware confujuration of your system, and look whether onboard audio is disabled. If it is disabled, inable it. If there is no driver installed to it, the system will ask CD. Then insert the CD into the CD tray, and follow the instructions. If your Win-7 is registered, you can get diretly into Microsoft site, and can download the driver needed. OK.
Jun 03, 2011 | Altec Lansing ATP 3W Computer Speakers
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
Kinect
Troubleshooting Kinect audio problems Page ContentBelow is a list of common Kinect audio problems along with suggested solutions.
If you are experiencing...
Try this...
An echo
  • Turn off digital effects on your audio receiver. Digital effects include things such as reverb, compression, and synthesized surround sound modes.
  • If you are using a TV and an audio receiver at the same, turn off the volume on the TV.
  • Use the Kinect Audio Tuner.
  • If you are hearing an echo during Xbox LIVE gameplay but not while you are playing offline, the problem might be with another player's Kinect sensor. Ask the other player to run the Kinect Audio Tuner.
No sound from one or more speakers
  • Make sure that the Xbox 360 A/V cable is properly connected to your audio system.
  • Make sure that all speakers are connected to your audio system.
  • If your audio system has speaker switches, make sure that the switches are on.
  • If your audio system has a receiver mode, make sure that the setting matches the number of speakers connected. For example, If you have Use this mode Two speakers Stereo Five speakers and a subwoofer 5:1 Seven speakers and a subwoofer 7:1
Kinect voice commands are not working
Run the Kinect Audio Tuner
Your friends cannot hear you during chat
Make sure that the chat microphone on the Kinect sensor is on. Here's how:
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Kinect Settings.
  3. Select Chat Microphone.
  4. Select On.
Dec 11, 2010 | Microsoft Xbox 360 Console
TV Surround System
Sadly enough RadioShack is slowly becoming extinct, but they were the best! P{rovided both components have standard audio/video cables witht he red yellow and white tips you would have to find the audio and line OUT on the video recorder and plug them in to an AUDIO and LINE IN port on the subwoofer and speakers.
If the speakers have serious connections like guitar amp plugin type, then you would simply need a converter wire that is perhaps the standard audio cable on one end and the type you need on the other and THUS - RADIO SHACK!! Love that place. Otherwise if I'm way off, a stereo receiver can be a mediator for the two devices but similar cables will be needed.
Oct 19, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Will not stay on
Hello-
I had the identical problem and solved it. It is a short where the speaker wires are contacting each other. Since my problem only happened when a DVD movie was being played, it had to be either the center or back speakers. Checked the center and found both speaker wires touching each other. A little wire shortening and stripping and re-connecting without contact solved the problem.
Everything is working perfectly now.
Good luck.
Barry Scholles
Strasburg, OH
Dec 06, 2008 | Yamaha HTR-5240 Receiver
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
Bose Lifestyle 28 System Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
