Question about Bose 3·2·1 Entertainment System System
Door on dvd player, sounds like a constant motor turning.
  • 55 Answers
The Belt under the tray streched or broke
Posted on Oct 08, 2010
DVD tray is stuck. No DVD inside. I've removed top cover and there is no obvious mechanical obstruction. I can hear the motor attempting to move the tray but there is no movement of the tray or other...
Helo tom,
According to your problem description, it seems to be the problem with the DVD door mechanism. To fix the issue door mechanism, you have to replace entire mechanism think it helps! Let me know.
Best Regards,
Chandrashekhar Bhat
Dec 25, 2010 | GoVideo DV2130R DVD Player / VCR Combo
While playing the VHS the player switches from VCR to DVD in the middle of the movie multiple times. We ended up having to tape the DVD player closed because it would turn the player on in the middle of...
Hi, it sounds like either the eject button on the DVD player drawer has been damaged or the remote is in need of cleaning (I assume the remote to have an eject button too). you can remove the remote by removing a battery and seeing if the problem stops.
Best you remove the tape from the DVD drawer as this will not stop the DVD mechanism from trying to open the tray, bit like trying to constantly push against a locked door - you will cause damage if it hasn't already.
Aug 13, 2010 | Zenith XBV442 DVD Player/VCR
Power is on door tray will not open with manual or
the possible problem of it is a defective mpeg board or the belt in tray to make it open if the motor have a supply to turn the motor the problem is the belt but if it has no supply from the mpeg to the motor the defect is on the mpeg board
Nov 18, 2009 | Denon DVD-2910 DVD Player
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
I have a broksonic sc-20145 and the dvd player drawer will not open/close. could it be a bad motor?
With your ear next to tv do you hear the sound of a motor trying to open the dvd door. If so probaly a plastic gear that has failed that opens the dvd door otherwise could be the motor. Just go buy a $30 dvd player and connect to the tv input. not worth repairing and stay away from tv/dvd combos in the future for this reason that your having to expierence now.
Aug 15, 2009 | Televison & Video
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
DVD player will do nothing
Ok so I took the cover off to see if I could figure out the problem. Don't have a complete solution, but I did get somewhere. There is a silver cylindrical motor attached to the eject mechanism wheels on the VCR side. When I unplugged the tape from the back of the little motor, the progressive light goes out and the sound from the motor stops. When I manually turn the wheel/arm attached to the motor, the other wheels/gears turn and I can manually eject the tape. Also when I get to a certain point, my progressive light starts flashing like yours was. Anyway it all seems to be related to the little motor. I figure if you replace that, it would work. At least that is what I might try, I'll keep you posted.
Aug 27, 2008 | Sony SLV-D300P DVD Player/VCR
Pioneer DVL-919 DVD door does not open
You can also try flipping the player upside down and shaking it a little. I bought a DVL 909 and when it arrived the tray wouldn't open. The seller told me to try that, and it actually worked. I wouldn't recommend shaking it quite so much as this video shows... but it does show that it can work.
Dec 14, 2007 | Pioneer DVL-919 DVD Player
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
Bose 3·2·1 Entertainment System System Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
