Question about Samsung Refrigerators
Ice machine is not making ice but the water still comes out
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Oct 08, 2010
Youtube
taste the water coming out of the filter ? should come from a cold water line, not the hot water line, funky smells and tastes come from your hot water heater. and I don't want to hear the hot water freezes faster bs. hot water heaters are full of stuff you don't want in your body. So if the water tastes ok....
sounds like you need to give the entire fridge a defrosting, clean it up real good. also have baking soda ready for monthly treatments, just crack a box open and stick it int the fridge or freezer.
These ice machines never did make quality ice as they just freeze still water, witch make cloudy, less than savory ice.
If you are a big ICE lover like me. a under the cabinet flowing ice machine is the best ice, as it last the longest(almost clear) and has no ill flavor.
Jay the pool pump guy longwood
Jul 25, 2014 | Whirlpool Refrigerators
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Not makeing ice
There could be over 50 things that will not let that machine make ice so help me out. when in freeze mode is compressor running, is condenser fan running, is water pump running, check condenser coil to make sure it's not full of dirt if so blow it out, cut machine off if water sump tray is full of water and you can still here water coming in at all check water flote to much water coming in all the time will not let water freeze. Fell evaporator plate while running if warm to touch could be hot gas valve letting hot gas in to plate in freeze cycle. you need to call a service company
Jan 08, 2014 | Scotsman Kitchen Appliances - Others
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
I have some problem with our machine scotsman mv450 is to long product ice very slowly
Min freeze time 6 minutes and max freeze time 45 minutes. the 6 minutes is with perfect conditions. Example: Cycle time water temp was 50 degrees coming in to the water sump tray from water supply and the Ambient air temp surrounding the machine was a constant 70 deg than the machine should make ice every 10 - 12 minutes.now we know that the water temp from the water source is not going to be 50 deg and room temp will not be 70 deg all the time so the warmer water temp and ambient air temp is the longer it takes to make ice. one thing you wont to check is the water inlet valve to make sure it is not letting water seep through causing water temp not to cool down from running across evap plates. make sure the condenser coil is clean this will slow down production of ice.
Apr 17, 2013 | Kitchen Appliances - Others
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Ice machine working but very slowly
I am not sure about the commercial ice, but I would check to make sure the water tube that goes into the maker does not have an air bubble in it. That can cause the water not to come into the freezer to make the ice cubes.
Aug 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine does not make enough ice
Check the water filters first. Then check the condenser coils for dust and dirt. Determine which way the air goes thru the condenser coils and check on the side the air goes into. There are coil cleaning sprays that work good. If it is still slow, it may need gas. That will require a service call from a technician.
May 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker not making ice
My ice machine stopped making ice after the city shut off the water line for more than 8 hours. How do I make it start making ice again.
Apr 23, 2008 | Refrigerators
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
