Question about Coldtech 21 cu. ft. / 595 liter Commercial Freezer J2SFF-21B
Completely dead - Coldtech 21 cu. ft. / 595 liter Commercial Freezer J2SFF-21B
  • Coldtech Master
  • 1,078 Answers
Let's start with the basics. Are you sure you are getting the correct power to the unit? If 120 volts, use meter and check across power and neutral, not power and ground. If correct power is present, check the defrost timeclock for proper operation. If bad and stuck in the defrost cycle, nothing will work except for the defrost heaters. It should terminate defrost cycle and return to the freeze cycle, but if terminator is bad, it will just sit in defrost. Start here and get back to me and we can continue.
Posted on Oct 16, 2010
Engel fridge trips power when mains power turned on. Fridge set in off position.
There is a dead short line to line or line to ground. The dead short can be detected with a electric continuity tester connected across the load side of the mains (power shut off) and opening covers and inspecting the wiring.
Aug 01, 2017 | Engel Freezers
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
20 cu ft freezer top 1 foot things don't freeze completely. Bottom 1 ft things don't freeze completely. But the middle 18 cu ft its frozen.
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Aug 22, 2011 | Frigidaire Freezers
Sears model 253.9280212 UPRIGHT FREEZER NOT KEEPING FOOD COMPLETELY FROZEN. EVEN AFTER HALF OF CONTENTS HAVE BEEN REMOVED, REMAINING CONTENTS DO NOT COMPLETELY FREEZE. WHAT'S WRONG? HOW TO ID PROBLEM?...
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
May 06, 2010 | Freezers
Auto defrost wont work check heater all good
Not very familiar with fisher however I have worked on a few for my friends. Usually the only other two things in a system would be your defrost termination and defrost timer. The more likely and cheaper of the two would be the termination which would be located on the top of the evaporator coils. You can usally visually inspect these and if they are bad they look (popped out). Lastly and most unlikely would be the defrost control. Usually if the control is bad the unit will be completely dead. Let me know if you need more help past the termination.
Jan 11, 2010 | Freezers
Fridge/freezer won't cool completely or freeze
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
May 09, 2009 | Freezers
Small frigidaire with very small freezer completely fill with frost
Most of the smaller freezers are not self de-frosting, Im not certain about the one you have but usually the only way is to unplug them and let them thaw out for a few hours. Make sure to put towels down to absorb the water or you may have a mess.
Jan 07, 2008 | Frigidaire Freezer Refrigeration White...
Coldtech 21 cu. ft. / 595 liter Commercial Freezer J2SFF-21B Logo
88 people viewed this question
Top Coldtech Freezers Experts
Dennis Boxerman
christian nielsen
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
