Question about KitchenAid Dishwashers
Top rack dishes not getting clean even when bottom rack is empty
  • KitchenAid Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Oct 07, 2010
The top rack dishes do not get cleaned. I have run the vinegar rinse. The bottom rack dishes get cleaned. It doesn't even look like the top rack dishes get wet. I ran the washer without the top rack in and...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Nov 06, 2010 | Dishwashers
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
