Question about Dewalt 2 Hp 4 GAL Air Compressor
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
    Scholar:
  • 146 Answers
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Posted on Oct 07, 2010
2 Suggested Answers
nampaboat
  • 150 Answers
SOURCE: dewalt emglo d55155 air compressor-what
Need to use air compressor oil it is available at you local hardware store in the tools department.
Posted on Feb 06, 2011
How much oil does the Dewalt emglo d55155 air compressor use?
Without knowing the exact model number, it looks like 4 oz. You can buy here for less than $6.00.
Bostitch CAP2000P OF Air Compressor Parts
May 27, 2017 | Dewalt Air Tools & Compressors
What type of oil to use
Use 30 wt oil and fill it up till it comes 1/2 way up in the bubble.
Mar 22, 2016 | Dewalt D55155 Emglo Air Compressor
When changing gaskets and valve blades on dewalt emglo dw55155 air compressor do I need to lubricate gaskets when putting back together
Depends on the type of gasket.
Not a good idea to lubricate gaskets generally. Rubber or cork gaskets that are lubricated tend to be squeezed out of the joint instead of being compressed. Sometimes it is a good idea to bond such a gasket to one face with something like a latex adhesive. Rubber gaskets that fit into a groove can be lubricated because there is no chance of them being squeezed out of the joint. I tend to use a wetting smear of silicone sealant for such joints.
Standard paper or composition gaskets should mostly be fitted dry if the faces are good but the careful application of jointing compound can help overcome rough faces. Choose a low viscosity compound for thin joints and progressively higher viscosities for thicker joints.
Nov 17, 2015 | Dewalt D55155 Emglo Air Compressor
I have a D55151 Dewalt comp. that wont pump past 40lbs. What can couse this??
I don't what you mean by a "cold start" valve? Too much typing for a guess.
Dec 11, 2013 | Dewalt D55155 Emglo Air Compressor
I want to know where the oil goes on this machine?
ON a d55155 compressor, you will find the dipstick on the left side as you are facing the control panel. Notice a small black knob on the end-bell of the pump. Pull out the dipstick and notice the oil level line just up from the tip of the stick. Over-filling will cause oil to leak. Use 30wt non-detergent oil or compressor oil. Good luck
Apr 02, 2013 | Dewalt D55155 Emglo Air Compressor
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
Nov 23, 2012 | Dewalt D55155 Emglo Air Compressor
I'm using my dewalt for bead blasting projects, Lately moisture is coming from the pistol
It's on the bottom, right hand side of the tank if you are facing the tank side. You can download the owners manual from this link. It is at the upper right side of the page in the section marked downloads.
DeWalt D55155 parts and owners manuals
Aug 21, 2012 | Dewalt D55155 Emglo Air Compressor
Dewalt emglo d55155 air compressor-what type of oil? this machine is electric
Feb 05, 2011 | Dewalt d55151 factory reconditioned emglo...
How much 30w oil does a D55155 hold
The compressor takes 4 ounces of oil to change the oil.
Oct 07, 2010 | Dewalt Air Tools & Compressors
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt 2 Hp 4 GAL Air Compressor Logo
1,417 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
