Question about ASUS K8V-MX Motherboard
Primary master hard disk error
When i boot up it said primary master hard disk error on bios setup dont reconize the Hd but on boot yes. i put other disk and this one was reconize. it means that the riginal one is damage or need to be formated?
  • 1 more comment
  • wilba63 May 30, 2008
    my motherboard is a asus kv8- mx and my hard drive a hitachi model ata/ide hds728080plat20 82.3gb .ihope this can help thanks
  • foru2004 Aug 15, 2008
    I have a HIS motherboard, Celeron 1.7 GHz.  I am trying to connect new SATA - 160 gb harddisk and make it primary.  If I connect the SATA harddisk only, the system does not detect it as primary, but secondary.  If I connect my old harddisk, it again detects the SATA harddisk as secondary.
    Please advise.
  • mike block May 11, 2010
    if it is having trouble recognizing it in bios, you may just need to change the detection settings in bios. what kind of motherboard do you have? and what kind of hard drives are you using? some motherboards have a function to change the type of hdd detection (raid, eide, sata, ect.) it may just be set wrong. also, check jumper settings on the hdd's. ive seen that goof a couple little things up too. agent 10708
I need the solution for hark disk error
Posted on Jun 10, 2008
I also need help
my motherboard cannot detect also my SATA harddisk
my Mother board is K8V-X but in boot options i see my harddisk
but in main menu no SATA..
so thats why i cannot reboot or reformat my pc
Posted on Jun 06, 2008
Primary Master Hard disk Error NO HARD DISK ON MY MOTHAERBORD
Not seeing hard drive. Make sure HD powers up. Check BIOS recognizes as master or eve recognizes. Check HD pins jumped to cable select or master.
Aug 25, 2012 | EliteGroup ECS G41TM7 Intel G41 Socket 775...
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
I want to boot from cd to change windows from xp to 98
enter the bios set up on start up. Go to boot sequence, change 1st option to cdrom instead of main drive. Save and exit. Let it boot up, put 98 disk in cdrom. Shut down, reboot and win 98 installation will begin asking you to over write existing ops sys. Choose yes and the install should be a breeze after this. Once xp is installed, dont forget to return to the bios and change back your boot sequence to hard drive as primary /master.
Sep 26, 2008 | Compaq Computers & Internet
Computer freezes when trying to detect S-Ata drive
Hi Eamon, download Samsungs drive setup utility, tools from Samsungs web site. Creat a bootable floppy drive setup disk or a CD bootable disk.
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Enable the SMART function using the setup software.
If you are going to use the Samsung drive as the primary master drive as the new C:\ you will need to enter the bios & set the Hard Disk Boot Priority, page 30 in you're manual to see the Samsung drive.
Connect only the Samsung into the system. Boot the system & use Samsung's software to setup the drive & format.
Disconnect any other hard disk drives that may have windows installed in it.
Mike
Jun 30, 2008 | EliteGroup K8M800-M2 Motherboard
Installing Hard Drive on Dell 8300
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Computers & Internet
Will not boot avaratec 3260
Most likely it is one of two things. Either your hard drive has died, or your hard drive is not properly seated in the notebook.
Check the drive to make sure it is seated properly and securely.
Restart your notebook, enter setup, select auto for the hard drive selection, save setup and restart.
If that doesn't fix the problem, you most likely will need to replace the hard drive.
Dec 15, 2007 | Averatec 3200 Notebook
Will not boot
Sounds like the hard drive or the controller went out on it.
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS K8V-MX Motherboard Logo
1,776 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
