Question about Goodman Heating & Cooling
Not cooling . fans on.it,s running out side. water is goes thur tub.
    Scholar:
  • 80 Answers
Restricted air flow to return air(check filter)
Dirty condensor coils
Low refrigerant
Failed start capacitor side to compressor
Bad compressor last resort!
Posted on Oct 08, 2010
Drivers side cooling fan not working
I would say that fan motor needs to be replaced ! Power goes through that fan motor through fan relay # 2 to the right cooling fan an on to ground completing the circuit an turning the fans on low speed ! Take a jumper wire from battery pos.+ to one side of the fan connector an a jumper wirer from neg.- to the other side an see if it runs . Cooling Fan Repair On Your Car
Feb 10, 2015 | 2006 Buick LaCrosse CX
Cooling fan moto
Several fans located thur out he copier to cool circuit boards remove heat or remove ozone.
Apr 07, 2014 | Minolta DI2510 Black and White Copier
The van is overheating. I have replaced the relay switch, removed the thermostat, the water pump is working fine..but it has 2 fans. one, the one on the passenger side doesn't come on. I have no idea...
First of all, the passenger side fan is for AC, and should come on when AC is on or defrost. Secondly, if you didn't have the heater on when you refilled the cooling system after thermostat was changed, it may just be an airlock. Run engine from cool with heater on and let it run with cap off and top it up as it goes down. Let it run long enough for rad fan to come on and go off 2 or 3 times, and keep an eye on rad level and top it up a couple of inches from top each time it goes down. Then put rad cap back on and try it. Let me know if that helps.
Aug 05, 2011 | 1998 Dodge Grand Caravan
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
Won't spin
Take the front panel off by using a putty knife to push in on the two clips at the top edge of the front panel. Now, pull the thin tube off from the left front side of the outer tub. Cut off about 1.5 inches of it and replace. Test. This tube tends to plug up right there. It's really best to just clean it out, as if the problem reoccurs, you will soon run out of tubing. I usually see this problem with machines which rarely, if ever, see regular liquid bleach used. To prevent this from happening again, fill machine to the lowest water level, using the hot water, and several cups of bleach (no clothes) and run a cycle through a couple times a year. Make sure to rinse machine before using with clothes again.
May 30, 2009 | GE Washing Machines
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Heating & Cooling Logo
35 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
