Question about Kenmore Washing Machines
My washer won't finish a cycle & then beeps stops the cycle & then the screen blinks 06 then F? I just recently moved & it worked fine before that. I already tried unplugging it for 10 mins to clear it, any suggestions? Its a kenmore elite smartwash quiet pak 9 HE 4t
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Posted on Oct 08, 2010
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Digital control panel is blinking on my neptune front loader!
My screen blinks when the room is cold. If we warm the panel up with a heating pad, it works fine.
Jan 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
183 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
