Question about Vacuums
Electrolux Epic 6500 SR ...no power to power nozzle. I think it is the switch in the handle because if I use my friend's hose/handle (same model), my power nozzle works fine when I turn on the switch. If you think it is the switch, can I get a part for it?
  • 694 Answers
That's about the best one to narrow down a problem, however, there could also be a break in your hose wiring. Switches, hoses, and hose handle assemblies are all available at your local Aerus Electrolux store. Simply take your entire machine in so they can check it to be sure what the problem is.
The nearest store can be found using the below site. Simply type in your zip code and press enter.
http://www.aerushome.com/storelocator/
Posted on Oct 08, 2010
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mick
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
How do i replace the hose on electrolux epic series 6500 canister vacuum
Cheap fix: DuckTape around the connections will work great
May 10, 2014 | Electrolux Vacuums
My electrolux Epic 6500 power nozzle Model N109J will not work. It had an intermittent short which I thought I fixed (some of the insulation on the wires were pinched). I fixed the wires and it worked...
The switch is definitely a possibility, but other problems can also cause this.
Bad switch, needs replaced.
Broken wiring in power nozzle, wands, hose, or canister.
Bad PN motor.
I strongly recommend taking it to the nearest authorized Aerus Electrolux store for a diagnosis (should be free). Allowing them to do any repairs necessary is recommended, as well. This will ensure it's done correctly.
Feb 23, 2011 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Parts for Electrolux Epic 6500
You need to look under AERUS Electrolux to find a Dealer with parts.
Electrolux USA sold the brand name back to AB Electrolux of Sweden a few years ago and there is no relation between the two.
You may also find a common component of a different color at a Tri Star dealer as they shared some power head and hose technology in the era of the EPIC although they don`t tell people that
Sep 14, 2009 | Electrolux Epic 6500 Vacuum
Power nozzle motor will not turn on
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Jun 22, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
170 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
