Question about Nautica Nst Chronograph Chrono Black with Orange N19510G Watch for Men
I have a NAUTICA WATCH STAINLESS STEEL CASE. WATER RESISTANT, 100 METERS JAPAN MOVEMENT N13531G Need to buy a new rubber band. Black or white. Where can I get it...?
5 Suggested Answers
SOURCE: watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Posted on Oct 15, 2007
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
cmcduncand
  • 714 Answers
SOURCE: need to set ironman 25
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 11, 2010
  • 19 Answers
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Posted on May 24, 2010
Is the fossil fs4813 waterproof
yes, to 50 metres
Fossil Men's FS4813 Grant Stainless Steel Watch with Leather Band ...
https://www.amazon.ca/Fossil-FS4813-Grant-Stainless-Leather/dp/B00AFTTQ8I
Rating: 4.5 - ‎50 reviews
Tang clasp. Water resistant at 50 meters / 165 feet. Casual watch style. Fossil Grant Chronograph Black Dial Brown Leather Mens Watch FS4813.
Grant Chronograph Brown Leather Watch - Fossil
https://www.fossil.com/us/.../grant-chronograph-brown-leather-watch-sku-fs4813p.ht... Rating: 4.6 - ‎91 reviews - ‎US$115.00 - ‎In stock
PRODUCT DETAILS. Collection: Grant. Movement Type: Quartz Chronograph. Case Size: 44mm. Strap Material: Genuine Leather. Water Resistant: 5 ATM ...
Water Resistant Watches, 10 ATM Watches ' FOSSIL
https://www.fossil.com/us/en/******/10-atm-watch.html Water Resistant Watches up to 10 ATM. Fossil Hybrid Smartwatch - Q Nate Dark Brown Leather Ftw1114. Quick Look. Fossil Hybrid Smartwatch
Is the fossil fs4813 waterproof Google Search
Aug 16, 2017 | Fossil Watches
At size is the battery in a mens fossil blue watch
take to Walmart and have them put in a new one .
Feb 15, 2015 | Fossil Watch
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
HOW CAN I FIND OUT THE MODEL OF MY WATCH, WITHOUT THE MANUAL... THANKS
Model id. is found on the back cover,after the module nbr in a frame.For ex.AW-500,GW-6900,GA-100 etc.
Jan 28, 2014 | Watches
What tools do i need to repair the band on my nautica steel 10071G watch?
GO TO EBAY AND SEARCH:
"NAUTICA REPLACEMENT BAND 100% ORIGINAL"
Sep 19, 2011 | Nautica N07518L Wrist Watch
How much
The Abyss 10.900 is a waterproof diving watch that features a silicone filled stainless steel case and stainless steel unidirectional bezel on a black rubber strap. Silicone is denser than salt water, making the Abyss water resistant to grater depths. 10.900 is the depth in meters of the deepest location on earth, the Marina trench in the Pacific Ocean. The refractive index of silicone enables you to see the dial and hands from any angle under water. You can typically buy this watch for about $425.00
Jul 17, 2011 | TechnoMarine Abyss ABS01 Watch
Can i buy a replacement metal wrist band for this watch? Model n19510
The only place you can get a replacement Nautica band is through Nautica. Here is a link to get you where you need to be:
http://www.nauticawatches.com/service
Best of luck to you.
Aug 11, 2010 | Nautica Nst Chronograph Chrono Black with...
Where can I buy a new White Resin Nautica watch band for Nautica N14537 Wrist Watch. Armando Mendizabal amendizabal@mayan-spa.com
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Jan 25, 2010 | Nautica N07574 Wrist Watch
Swiss g10-211 movement doesnt keep time runs when it wants to
This movement wasn't meant to be repaired, so replacement is your only option. These pop up new on eBay from time to time for around $30 shipped. Make sure you get one with the date in the correct orientation/position (e.g. date at 3 o'clock or date at 4 o'clock). Best to enlist the services of a watchmaker if you haven't removed and replaced hands on a watch before (particularly a chronograph).
Feb 25, 2009 | Swiss Legend Chronograph Stainless Steel...
Watch band repair
Oct 31, 2006 | Nautica N07518L Wrist Watch
Nautica Nst Chronograph Chrono Black with Orange N19510G Watch for Men Logo
321 people viewed this question
Top Nautica Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Nautica Watch Expert? Answer questions, earn points and help others
