Question about Hella Performance Headlamps H3 Xenon Blue replacement bulbs(100 Watt offroad use only)
2001 Audi Allroad: My left Low Beam bulb flickers on and off on occasion. I have replaced the bulb twice. I need Help
Low beam bulb replacement passenger side for a 2008 audi 4a
I suggest you refer to the owners handbook which contains adequate descriptions of how to access and replace the bulb(s) and what precautions must be taken and provides some illustrations.
European laws expect owners to change the bulb or bulbs as soon as possible after failure and in some European countries replacement bulbs must be carried. As the Audi is a European car bulb replacement is unlikely to be difficult.
Feb 25, 2015 | 2008 Audi A4 Sedan
Where is the data link connector for audi 2001 allroad?
The port is located on the lower dash knee bolster, near your left knee when seated in the drivers seat (assuming Left hand drive) near the hood latch
Dec 15, 2013 | Audi AllRoad Cars & Trucks
Horn does not work in 2001 audi allroad, why?
could be horn (high or low tone?) could be fuse if both arent working or clock spring.
Nov 29, 2012 | 2001 Audi allroad
On my `06 Dodge Ram 1500 my left LOW beam doesn`t work ALL other lights work fine. Only low beam on drivers side. I tried 3 new bulbs,didn`t help.
You probably have a bad plug or a broken wire on the low beam of the left side. I would replace the plug for the bulb and run a wire from the low beam on the right side or , locate and bypass the bad section of wire going to the current plug if the plug is still good.
Nov 05, 2010 | 2001 Dodge Stratus
Audi A4 2002 Low beams & Right front turn signal stopped working
For Audi A4 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
First fuse on first row from left upper corner is Fuse Nr.20 = F20 (15A) - RH headlamp low beam, headlamp adjustment.
First fuse on second row from left upper corner is Fuse Nr.21 = F21 (15A) - LH headlamp low beam, headlamp adjustment.
Feb 15, 2010 | 2002 Audi A4
Left zenon low beam flickers and the left front bulb warning indicator is on
Sounds like the power ballast is failing - that's what takes the 12v signal from the car and amplifies it up to a level sufficient for driving the xenon bulb. Swap the ballasts between the headlights (they're easy to dismount) and see if the flicker goes to the other side (swap only the ballasts - leave the bulbs in their existing positions). If the flicker moves to the other side, the ballast is the problem. If it stays on the left side, the bulb needs replacement.
Search online for the bulbs - the dealer will kill you on pricing (the Audi dealership wants $200 each for my A4's xenon bulbs, but I can find them online for about $30 per pair (or less)). You'd want to order a D2S style bulb for an OEM BMW fitment, in 4300k color temperature.
Nov 17, 2009 | 2003 BMW 330
Where can I find a user manual for an Audi A6 Allroad 2001?
Google this "User manual download for Audi allroad" and a whole list of sites come up all with free downloadable manuals.
Hope this helps!
Andrew
Oct 09, 2009 | 2001 Audi allroad
Left low beam headlight on Chrysler 2003 T&C wont work while engine is on
Ill guarantee you have an electrical short on the left side of the headlight switch,circuit.From here its immpossible for me to go any further.Good Luck.,Get A Wiring diagram.
Apr 18, 2009 | 2003 Chrysler Town & Country
How2 remove headlight to replace the low beam bulb on 2001 Lexus
Go to any autozone and they will help you replace it as long as you buy the bulb from them.
Apr 01, 2009 | 2001 Lexus IS 300
Hella Performance Headlamps H3 Xenon Blue replacement bulbs(100 Watt offroad use only) Logo
53 people viewed this question
Top Hella Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Hella Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
