I have a IBM Thinkpad T20 Laptop. I need to install a new hard drive and I am not to sure how to do it. cAN YOU HELP?
    Master:
  • 388 Answers
You will need.
a philips or cross screw driver
the new HDD (hard drive)
and an instalation disk either XP, vista or linux.
uplug from the mains and remove the battery on the bottom of the comp you will see two large panels remove the you will find the hdd under one of them.
remove it the hdd will be held in a bracket type thing we call a caddy remove it and put it onto the new hdd insert it into the comp screw the panels back on replace the battery turn it over plug into the mains.
start the computer go into the BIOS push F2 i think go to boot and select the 1st boot from cd open the cd draw place in the cd close it push F10 it wil ask if you wish to save and exit push yes.
the computer will now shutdown and restart you will get a message in the top right screen push ant key to boot fron cd.
now folow the on screen prompts and ya done.
Posted on Oct 07, 2010
I want to boot my laptop from a external hard drive. It is an older PC, a IBM Thinkpad T20. How can I boot from an external hard drive? Can anyone help me?
during start up press f12 key then when boot order opens select where you want to boot from . save then exit in to start up . that should do it . :)
Jul 10, 2010 | IBM ThinkPad T20 Notebook
Does not recognize hard drive
1. try reseating it if that doesn't help you might have a hard-drive failure. the only way to be sure is trying a replacement drive (maybe you can borrow from someone or from another laptop - currently on laptops there are 2 types of hard drives IDE and SATA don't mix them up, they are not interchangable)
May 25, 2010 | IBM ThinkPad T20 2647 Notebook
Can Windows XP Pro be installed on an IBM T20? I'm
yes you can. I checked e-bay and there are lots of them with windows xp.
Sep 09, 2009 | IBM ThinkPad T20 2647 Notebook
Processor and Disk space
The biggest processor available for the T20 is 1ghz. Be sure when replacing the processor that you get an IBM 133mhz processor. The memory is 1g max, the machine will hold two 512mb chips, and be sure that it's PC133 memory. You can put up to a 120g hard drive in the machine, be sure the hard drive is an IDE 4200rpm drive. These are the specs for the T20, and the maximum size this machine will hold. You can go to this max or anyplace in between.
Aug 27, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm thinkpad t20 notebook
Bad connection from your hard drive to the laptops motherboard. ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf page 63 tells you how to remove the hard drive - I would take it out, clean the connections with rubbing alchohol, and FIRMLY put it back and see if it will come up then.
Apr 02, 2008 | IBM ThinkPad R51 Notebook
Could be a problem with the MBR or Master Boot Record.
It could be damaged. It's only a file system type problem not a hardware fault.
Have a look here.
http://www.ambience.sk/fdisk-master-boot-record-windows-linux-lilo-fixmbr.php
Mar 09, 2008 | IBM ThinkPad T20 Notebook
Ibm think pad t20
Make sure your replacement hard drive is compatible in geometry (supported by your ThinkPad T20). Check and see if your BIOS setup utility has an auto-detect function.
It would be good if you knew the contents of your replacement drive. You said it might be installed, it might not. If there is nothing on the drive, the ThinkPad should report 'no operating system' or similar message, but it is possible that it might not show anything other than a blinking cursor
Dec 13, 2007 | IBM ThinkPad T20 2647 Notebook
Install hard drive for t20
So, what is it you want to do?
The hard drive on a T20 is in a slot on the left side of the unit, and it's cover can be taken off by removing 1 screw on the bottom just under the sound ports.
Hope that helps.
Nov 25, 2007 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T20 - Model Type 264784U
I would say the hard drive is failing. But need to run a diagnostic on it to be sure.
If you would like to know where to get the ibm / hitachi hard drive diagostic let me know. It's free for download and you can get a bootable ISO image to burn onto cd. Allowing you to boot from cd in order to test the drive.
As far as replacing, you should be good with a 60gb or 80gb. Did it orginally have a 20gb in it? I would say for most people, 60-80 is way more than enough. Unless you have a ton of music or pictures.
Oct 22, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
