Question about Toshiba Computers & Internet
My laptop restarts everytime i connect it to adc adapter, but it operates properly when using the battery, i encountered it several times when I'm charging my battery or using only the adc adapter, what is the probable problem? thanks
    Master:
  • 388 Answers
You have the wrong adapter or the worong voltage.
Posted on Oct 07, 2010
I have a HP Probook laptop 6555b and last week while using it , it displayed that it was not charging. I checked the connector with a multimeter and found it was damaged.I replaced with a spare one t
Check your Adapter Cables properly connected or take your battery from the Laptop and put it back. Then try restarting. If nothing helps check your Adapter with another same model Laptop. If the Adapter working well then your Battery is dead!.
Dec 01, 2014 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
Hi dear, i have a lenovo Z560(core i3-4GB RAM-without dedicated VGA). and i have complicated problem with that. it's running as well with power and also with battery. i turn it off, restart, sleep and...
Welcome to FixYa! I'm really sorry that you are encountering that kind of problem. It's really an inconvenience for you if you always do that everytime you use your computer. Please follow these steps to isolate the problem.
1. Removed the battery and connect the laptop directly to the power outlet.
2. Monitor the laptop if it will act the same way.
3. If it's the same, try to use the laptop with just the battery alone.
4. Monitor the laptop again.
5. If it's still the same, you will need to contact lenovo to check the laptop because there's a possibility that the problem is with the power supply inside the laptop or the Motherboard itself.
Hope this information will help. Thank you for using FixYa!
Apr 02, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Hi. I having a problem with my loptop Packard Bell EasyNote R1910. Sometimes its can't start up. it power up per several times. When it starts he's working perfectly but when i move it it's restarting or...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 20, 2011 | Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Runs at work, error at home
the restarting is an OS Problem . Please send More details . Regarding Error Code
Mar 25, 2010 | Microsoft Windows XP Home Edition
Refrigerator runs, cools (freezer too), then stops cooling for a few days (freezer stays somewhat cool), then starts cooling again. Help...:(
In these new fangled ice boxs is what you call adaptive defrost control. Instead of the old tried and true defrost timer, brainiacs have decided to use artificial intelligence to determine defrost.
The basic pattern of adaptive defrost is:
COOLING,PRE-CHILL,DEFROST,DWELL,and POST-DWELL.
Hey I ain't making this up. The ADC (adaptive defrost control) Counts the number of times the doors are opened, the total compressor run time, and the length of time the defrost heaters were on during the last defrost. This method supposedly enables the adc to work nice in all kinds of conditions, whether hot and humid or cold and frigid climates. COOLING Mode will remain for an indefinite time or until defrost is determined by the micro-processor. When all systems are go for defrost the adc makes the jump to light speed by going into PRE-CHILL, this brings down the temps in the freezer to off set the defrost operation so that the food temp does not suffer dramatic temp rises. Pretty cool ain't it? If the ice box is in pre chill and the door gets opened then a DEFROST HOLD OFF will jump in and not do a defrost for several hours. If the door is continually opened at the end of 16 hours the adc is gonna defrost that ice box anyway. The defrost period varies but is a maximum time of 45 minutes including when the DWELL kicks in. Dwell is the length of time the ice box stays off AFTER the heater is terminated.
Then The POST DWELL will kick in. The post dwell will fire up the compressor and condenser fan but the inside fans will not run allowing the coils inside to cool down before them fans kick in and she jumps back into Cooling mode. I bet you would like to have a copy of GE's adc repair manual wouldn't you?
TECHNICAL SERVICE GUIDE
Dec 22, 2009 | Kenmore Refrigerators
HP DV2000, one long beep followed by two short beeps...doesnt boot up. after repeated attempts, finally got one solution (sounds silly though), but works everytime for me. i plugged power supply and kept...
Hello there yog26.
Those beeps you hear are a trouble report your BIOS is trying to tell you about in the only language she knows.
1 long, 2 short beeps indicate the following pre-scripted error message:
"Video adapter error: Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly."
  • The "video adapter" is the physical device (aka card).
  • "not seated properly" means connecting cable(s) are not full-in connected.
Corrective actions will require opening case and physically inspecting connections, and if still troubled, swapping out the video card with a "known good" one to test.
If that is beyond your geek-ability, it's PC tech repair time.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 14, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Targus Adapter is Freezing my computer!
This adapter is obviously not compatable with Vista as it was originally used in Win98, Win2000 and XP and there are no drivers on this site for Vista. http://www.targus.com/us/drivers_manuals.asp?SKU=ACB10US For the price of a new Vista compatible Bluetooth adapter it's not worth re installing another operating system as all adapters should have all the same uses as each other.
Mar 07, 2007 | Targus (ACB10US) Bluetooth Wireless...
Computers & Internet Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
