Question about Juki DDL-8700
I was sewing on my machine when all of a sudden the top wheel locked up . The motor wheel turns the belt will turn , but of course it smell as burnt rubber. I'm on a limited time frame and my work has to be done asap . I hope you can help. Thank You---Betty
    Scholar:
  • Juki Expert
  • 176 Answers
Hi there
first you must upper maun shaft by losse screw for neddlebar and move handwheel by hand if move it means needle bar is jamd and need to change.
- second : maybe there is some threads at finger for lock lower hook this also made machine is locked please try to remove this finger by loose screw and move handwheel if realse ok.
please check this two points and if need more information send me email i will send to you service manual it can helped you
best regards
ashraf abozid
aabozid@hotmail.com
Posted on Oct 08, 2010
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
HOW TO CHANGE THE OLD BELT ON THIS MACHINE
The one thing on a sewing machine that needs the most repair work is the belt. The sewing machine belt is a piece of rubber that makes the wheel turn and the needle go up and down in a sewing motion. If the belt is in bad shape, the sewing machine will not work. Sometimes while sewing you may notice a burnt rubber smell. When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; just make sure you have the proper belt.
Dec 08, 2015 | Sewing Machines
My sewing machine want sew bought a new foot pedal
possibly the belt is broke or the motor has burnt out
May 30, 2015 | Sewing Machines
Sorry the needle is not going down,
Needles will not go down for:
1. The lock on the hand wheel isn't locking. Try this
a. Loosen the lock like you're going to wind a bobbin.
b. Loosen screw that is on the side of the lock. (sometimes front)
c. Tighten the lock just like when you're going to sew.
d. Tighten the screw that is on the side of the lock.(sometimes front)
e. Turn hand wheel by hand. Did the needle rise and fall?
2. The drive belt isn't moving the shaft.
a. Remove the top of the sewing machine.
b. You will most likely have to remove the panel on the end where the hand wheel is.
c. Turn your hand wheel to see if the belt is moving the shaft or is it broken?
d. Replace if you need to. (look at wear). Loosen the motor.
e. Make your motor run (foot pedal) slowly. Tighten the belt by pushing on the motor while it is running. When the motor is placed at the right place the motor will be moving with very little drag. (This will need a listening ear)
f. At this point tighten motor and retest for the speed and drag.
Mar 21, 2015 | Sewing Machines
My Singer sewing machine model 500A is slow and I see and smell smoke
This sewing machine doesn't have a belt. The motor is bad or the gears between the motor and the upper horizontal rod is worn. Remove the hand wheel by removing the screw from the outside edge. Then you can turn the brake (in center) and pull the assembly off. Take the gear out from inside by sliding it out. (Remember order) N
Oct 23, 2014 | Sewing Machines
My hand wheel turns and my needle stops even thou I have it turned so that it should sew. I will be sewing along and all of a sudden the hand wheel starts turning.
If this is an older machine that the motor drives the hand wheel with a belt, then look at what holds the wheel to the interior shaft (a bolt, screw, or friction knob that releases the interior shaft to allow winding a bobbin). Hope this helps!
Mar 27, 2010 | Sewing Machines
Viking 6000 (model 6440)sewing machine - replacement motor
a quick check on your motor. If it gave a lot of smoke and really thick and heavy oily smell all of a sudden, then your capasitor blew. your machine can work without it. Test your machine to see if it still work as normal. Your motor is still good then and only needs replacing fo the capasitor. This is a common problem!!
Jan 24, 2010 | Husqvarna Sewing Machines
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Juki DDL-8700 Logo
270 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
